Results 1 to 11 of 11
Thread: Brakes on a budget
08-09-2006, 12:09 PM #1Out in the garage...
- Lakeland, FL
Sebring Silver- 2000 Camaro SS (R.I.P.)
Brakes on a budget
I need brakes, but I can't afford a complete Baer or Wilwood system. My calipers are fine so all I need to replace are the pads and rotors all around. I've heard the Autozone rotors are good - can someone confirm that? As for pads, I was wondering if the ceramic pads were worth the extra cost.
Any info would be great.-- J. Bennett
1999 NBM Camaro SS #4312
SLP lid w/ K&N, Delphi/Lucas 42lb injectors, Pacesetter coated LTs, ORY w/ dual cutouts, Magnaflow exhaust, Spec 2+ clutch, Strange 12 bolt, Detroit Truetrac 3.73 gears, BMR adj torque arm, BMR SFCs, BMR LCAs, BMR adj panhard rod, 18" chrome ZO6 wheels
08-09-2006, 01:38 PM #2
If you cant afford too pick up some slotted rotors then im sure chinazone's rotors will work. Make sure you get some type of warranty with them.
I would reccomend ceramic pads bc of the factors of squealing and dusting.
The make less noise when braking and produce lest dust so all around a better pad. Again make sure you get ones with a warranty just incase.
08-09-2006, 01:46 PM #3
i went to myanike (cant spell, that is phonetic) and they used raybestos rotors and they are workin great
anything will work good unless you beat on them
08-09-2006, 08:13 PM #4Junior Member
- Mar 2006
- omaha ne
red- 98 Z28
Im running rotoworks cross drilled and slotted rotors all 4 and hawk hps pads...the rotors were 169.99 and pads 129.99 from the ws6store.com work great have no problems stops good and cheap!!!
08-09-2006, 08:15 PM #5
If money is an issue have you thought about just having your stockers turned? Less than $10 a piece usually. Just an idea.
08-09-2006, 09:13 PM #6Member
- Tulsa,OK
Quick Silver- 2002 Z06
I have ran the Autozone cheapies and they do work fine for the most part. Every semi hard/quick cuz you saw a cop stop at 65+ eats there life into warp ville quite quick. But if you keep from that and treat them like you love em they are great for the budget they require.
08-10-2006, 08:21 AM #7Out in the garage...
- Lakeland, FL
Thanks for the replies. I'm not completely broke, just cheap. I just want the best value for whatever I buy.
BTW, GM rotors suck and I want new ones.
08-10-2006, 08:45 AM #8
I Went With Power Stop Cross Drilled Rotors. $100 Bucks A Rotor Though, Don't Know If That Fits Your Budget Or Not. Only Thing I Don't Like About Them Is When Your Hard Into Braking They Roar Loud. My Stock Rotors Were Warpped At 25,000
08-10-2006, 12:46 PM #9Senior Member
- Feb 2006
- Orange County, NY
i put on a set of baer stock replacement rotors that are drilled. they cost less than 300 for the pair. i also used ceramic pads and everything is holding up well. they seem to be much better than the stockers with less fade and brake dust.
08-10-2006, 12:52 PM #10
I used a cheap set from kragen about 15k ago, they get abused and i've had no warping. cdns rotors are a waste of beer money.
08-11-2006, 08:06 PM #11Member
- Aug 2006
- california
allllllllll black- 2002 35th z28
SUNSETORANGESS---CHINAZONE i f ing love it
is a perfect analogy......
but i agree with orion if your going to run cheapos might as well turn yours
House Budget Bill Punishes IRS, Slashes budget and Obamacare
By wileyCoyote in forum Political / Debate ForumReplies: 9Last Post: 06-19-2014, 10:16 AM -
Brakes - Road Racing Brakes
By Intrepidman in forum General HelpReplies: 6Last Post: 03-30-2010, 08:49 PM -
1966 El Camino Brakes - Brakes In a Box
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 06-06-2008, 10:10 AM -
Vintage Pontiac - Rear Disc Brakes On A Budget - Parts Bin Binder Bash
By Ed Blown Vert in forum GTOReplies: 0Last Post: 09-29-2007, 06:50 AM -
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 09-18-2007, 07:40 AM
