08-08-2006, 11:33 AM #1
LS1 Block w/ ARP Main Studs, Eagle H-Beam Rods, and More
*I have a stock bore LS1 block with a fresh hone (only 150 miles) and a
standard crank.
*The block currently has ARP main studs and stock main caps but I would be
willing to put the stockers back in if you didn't want the studs.
*It also has new cam bearings in it. (150 miles)
*I have 2 cranks.The one crank is fine but I would polish it, but the other
spun a bearing and would need to be turned.
*I also have the stock rods with new ARP 2000 rod bolts and stock pistons
that have been flycut to 4cc reliefs with new total seal rings (150 miles)
* 28# injectors out of a Camaro SS
Block-$350 + Shipping on the block will run $155 anywhere in the lower 48.
Crank std/std-$175
Eagle Forged H-Beam 6.125 w/.927 wrist pin - $335
Stock Pistons w/valve reliefs & rods w/ rod bolts- $125
Crank needs turned - $50
Injectors - $100
All items are best offer and are + shipping. Shoot an offer if interested.
I am sure I have other things for sale that I will add later.Last edited by greatwhitess; 08-09-2006 at 12:17 PM.
08-08-2006, 11:08 PM #2Member
- Nov 2005
- allenhurst GA
- iTrader
- 0
onyx black- 1999 formula firebird
do you still have the block? and what year is it from? how many miles were on it?
08-09-2006, 03:47 AM #3
Yes. It is out of a 2001 Camaro SS. Right at 54,000 on the block
08-09-2006, 12:17 PM #4
04-08-2009, 09:16 PM #5Junior Member
- May 2008
- Dallas, TX.
- iTrader
- 0
Blue- 1999 Pontiac Trans Am
Do you still have the 6.125 rods?
5.3 block, stock LS1 rods etc.
By jjz28 in forum Parts For Sale / TradeReplies: 5Last Post: 04-14-2010, 10:00 AM -
Eagle H-Beam Rods
By greatwhitess in forum Parts For Sale / TradeReplies: 3Last Post: 04-12-2009, 05:36 PM -
ARP Main Studs and Rod bolts
By greatwhitess in forum Parts For Sale / TradeReplies: 0Last Post: 08-07-2006, 06:51 PM -
Mahle Pistons, H-Beam Rods On Ebay??
By shortdog in forum Internal EngineReplies: 0Last Post: 03-12-2006, 06:59 AM -
ported ls6 heads ls6 block crank and rods.
By roadrash9r in forum Parts For Sale / TradeReplies: 7Last Post: 09-24-2005, 01:29 PM
