Results 1 to 20 of 22
    yorktown, va
    arctic white
    trans am rear filler panel black out
    im tryin to figure out how to black out the rear filler panel- the piece b/w the reverse lights that say trans am andhas the bird- i threw some overlays on there but there slightly off and u can see the letters. i want it all smooth all black. ya'll know anything?
    LA
    Grey
    2010 Camaro 2SS/RS CGM
    well you can wetsand it with 1000 grit or you can use some nail polish remover.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    wet sand to get it off then buff it out
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    http://www.ls1.com/forums/showthread...illight+center
    'Search' function is your friend, ..., 'Center taillight', 'polish' or 'polished', ..., etc., ...
    Follow the directions & you should achieve what you're looking for.
    Motorized tools will complete this job much faster than by hand also.
    Start with nail polish remover to get rid of leftover red/pink paint.
    Then wet-sand, then polish.
    And Welcome a'board', ...
    Edit added:
    (From some of my previous posts, ...)
    I've done literally DOZENS of these things over the last couple years, ...
    Yes, nail polish remover will remove the leftover red fading ink first.
    I start with a 600 grit, keeping it wet, using a small 1/4 sheet sander.
    Then on to 1200-1500 by hand, then finish by hand with 2000 grit, keeping them wet while sanding to wash away the contamination.
    Then I use an old Black & Decker orbital polisher with Zaino's Glass Polish first,
    You'll get the same/similar description by most anyone else who has done it. Although some may not put that much work into it, .... You can also use other brands of polish. I've tried others, but didn't get the same quality results as I do with the Zaino process.
    Good Luck!
    (By the way, I do all this with the units screwed down to my temp workbench work surface. Not on the car.)
    And yes, you can buy them from GM without the text/bird, or even other colors of the text/bird already. But they'll cost ya a lot more depending on the style you want.
    All from GmPartsDirect.com
    Firebird tail filler panel (from 93-97 Firebird V6) = 5977293---------------------$105.60 w/s&h&tax
    Firebird tail filler panel (from 93-97 Formula) (plain black - no logo) = 5977294--$102.13 w/s&h&tax
    Firebird tail filler panel (from 94 25th Anniv TA) (white logo) = 5977296--------- (Not available anymore)
    Firebird tail filler panel (from 93-94 Trans Am) = 5978095----------------------$100.72 w/s&h&tax
    Firebird tail filler panel (from 95-97 Firebird 3800 GT V6) = 5978095-------------$100.72 w/s&h&tax
    Firebird tail filler panel (from 95-98 Trans Am) = 5977286-----------------------$95.65 w/s&h&tax
    Firebird tail filler panel (from 99 Trans Am) = 5978095--------------------------$100.72 w/s&h&tax
    Firebird tail filler panel (from 99 30th Anniv TA) (white logo) = 16525477--------$97.70 w/s&h&tax
    Firebird tail filler panel (from 00-02 Trans Am) = 5977286 ----------------------$95.65 w/s&h&tax
    Firebird tail filler panel (from 02 CETA) (silver logo) = 10312725-----------------$108.09 w/s&h&tax
    And for decals, I'd also recommend,
    bfranker.badz28.com/vinyl/vinyl.htm
    allenhurst GA
    onyx black
    1999 formula firebird
    um...wow..thanks...!
    Ride Fast or Be Last ViperSniper's Avatar
    Ma
    2005 Mustang/2008 Viper
    98 & 01 Trans-Am WS6
    Hey Pontiac Fan,
    you have Pm's and a delivery from your USPS.
    Member 98ramairguy's Avatar
    Hamburg, NY
    1998 Trans am WS6
    I just went to order one of the CETA Trans am Filler panels from gmpartsdirect.com and it says they are discontinued. Does anyone know where I can still get one? I procrastinated to long, I hope Im not screwed
    1998 Trans am Ws6, T56 : SLP Lid, K&N Air Filter, Smooth Bellows, Granatelli air foil, LS6 Intake, SLP Harmonic Balancer pulley, QTP 1 3/4" headers and Y-pipe, LS7 Clutch & flywheel, Hurst Billet Pro shifter,Tick Master Cylinder, UMI LCA relocation kit, UMI LCA, UMI Panhard Bar, Tuned by Frost
    check with 6LE
    search google for 6litereaterdesigns
    Hamburg, NY
    1998 Trans am WS6
    I checked with 6le no luck. Anyone have any other sources?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    What about Hawksthirdgen?
    Hamburg, NY
    1998 Trans am WS6
    Hawks doesn't have it either. I know they used to. Doesn't seem like anyone has them anymore
    North Jersey
    2004 GTO M6
    Folks must know these cars are collectibles and are snatching up as many parts as they can get to either sell, or for collector's sake. Might have to check ebay or like previously suggested, wet sand, etc yours or get another panel and prep/paint.
    Hamburg, NY
    1998 Trans am WS6
    I may justgo the wet sanding route and put a vinyl decal on it. Not my first choice but may be my only option
    North Jersey
    2004 GTO M6
    Just an idea, but why not have a gunmetal overlay made? Kinda like a "ghost" bird.
    Hamburg, NY
    1998 Trans am WS6
    Well I found the new CETA panel on ebay and people are trying to get $400-$575 for them. That's crazy considering a couple of months ago you could get one from gmpartsdirect.com for $110. Looks like I'm definitely wet sanding and getting a decal
    Hamburg, NY
    1998 Trans am WS6
    New problem, cannot find the CETA vinyl overlay in silver like I wanted. Fourth circle designs used to have them now I cant find them anywhere. Can anyone help?
    North Jersey
    2004 GTO M6
    Try graphics websites that also deal with vinyl decals.
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    Trans Am Tail Light Bird Overlay Decal Fits 93 02 | eBay
    Used this one on my battery cover nice decal
    024mula 024mula's Avatar
    Dec 2010
    Ohio
    '02 Firebird Formula
    I got this (the formula on the third brake light) from www.CustoLight.com years ago, I don't even know if their still in business.
    It seems to be painted on. They did a good job. But it took awhile.
    Hamburg, NY
    1998 Trans am WS6
    I contacted fourth circle and he has them they just aren't listed on his website now due to reworking his license with GM. Got it shipped for $11 cant beat it.
  1. black rear filler panel
    By TransAm11973 in forum Parts Wanted / Trade
    Last Post: 02-12-2008, 10:33 AM
  2. Rear filler panel
    By TransAm11973 in forum General Help
    Last Post: 01-30-2008, 01:11 PM
  3. Polished BLACK Center Filler Panel 93-02 TA
    By myws62fast4u in forum Parts For Sale / Trade
    Last Post: 12-03-2006, 11:17 AM
  4. Pontiac Plain/Black Filler Panel
    By fierce-ls1 in forum Parts For Sale / Trade
    Last Post: 11-23-2006, 01:39 PM
  5. trans am rear filler panel black out
    By tawhite160 in forum Firebird / WS6
    Last Post: 08-12-2006, 08:28 AM
