Results 1 to 10 of 10
    ND2SPD 02T/AWS6's Avatar
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    rear-end backlash
    my 02 WS6 6-speed seems to have a lot of play in the rear-end i believe there's too much backlash in it, i know trans am's are notorious for having "loose" rear-ends however i don't think it should be this bad. I mean i feel it clunking practically every shift especially in traffic when putting the clutch in and out in first gear. I know you can't see my car so u don't know exactly how bad it is however, do u have any suggestions on what i could try to see if there's too much play in the rear-end??
    Junior Member JROBINSON1016's Avatar
    NORTH CAROLINA
    RED
    1998 TRANS AM
    how many miles does it have on it?& do you drive it hard?sounds like you may have a bad u joint or trans mont.if your backlash was too loose,your diff. would be whining,if it's as bad as you say,it probably would be broken.doesn't sound like a problem with backlash,i mean we're only talking like.08-.12,(that's thousandths).
    Awaiting Activation jsremmos's Avatar
    Tyler,Texas
    Black on Black
    2001 Trans Am ws6
    Mine does that a little too when i first heard it i was like what the f*** it does it only when im in 1st going about 25 to 30 mph when i let of the gas and then get back on it. it also does it sometimes shifting into 2nd does anyone know how much damage this can cause if any?
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    my car has 42000 miles on it and i've been told that because i have the t-56 tranny that i actually have a tight driveline and thats why i can feel my rear-end clunking, however i do beleive that its more that it should be....
    NORTH CAROLINA
    RED
    1998 TRANS AM
    well,it has very low miles on it,& no doubt that the driveline is tight.but there still shouldn't be any clunking going on.I've had many straight drives & automatics,and unless somethings wrong,there shouldn't be any clunking.especially if it's good & tight,like it should be.personally, I'm tending to think tranny mount,with a manual its not very tough to rip that sucker loose.I mean dump the clutch a couple of times & cut up a little bit & it's pretty much toast.very easy to check,when you're under there,put a jack under your tranny pan & lift it a little,if it's broke it'll lift,if not you'll know ,dont put too much pressure on it.after that,while your under there,check those u joints,might as well check bushings too.
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    yeah it turns out my whole rear-end is shot, just what i figured too well hopefully the dealer where i bought the car will take care of it seeing it is under warranty, however if not does anyone know where i can find a whole 100% complete rear-end for a 2002 trans am ws6 used is perfectly fine
    NORTH CAROLINA
    RED
    1998 TRANS AM
    got ya covered,cleveland pick a part,866/236-5031.$350 + s&h.around30,000miles.plenty of stock.or go to their ebay store (cleveland pick-a-part)best deal around w/guarantee.
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    thanks a lot i appreciate it!
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    If I shift quickly as low RPM's I get a clunk too, I think its the trans support mount (side one) though. The shiter will also bounce up and down like crazy if I short shift gears and let the clutch out fast, its ridiculous
    NORTH CAROLINA
    RED
    1998 TRANS AM
    Yep,sounds Like The Trans Mount.if Your Shifter Is Jumping Around,you Definitely Need To Check It Out Before You Cause Damage To Other Components.besides,it's Not Expensive,and You Can Do It In A Very Short Amount Of Time.
  1. Let the backlash begin
    By Sarge in forum Political / Debate Forum
    Last Post: 08-25-2009, 05:33 PM
  2. Too much backlash??
    By GottaHaveLS1 in forum Drivetrain
    Last Post: 07-18-2009, 05:50 AM
  3. Setting Backlash
    By 98formy in forum Drivetrain
    Last Post: 08-22-2007, 06:43 AM
  4. Replies: 0
    Last Post: 05-25-2007, 10:37 AM
  5. Backlash off or normal? AA&M 4.10's
    By 99RedTa6spd in forum Drivetrain
    Last Post: 11-01-2006, 05:42 PM
