    Minnesota
    1987 Trans Am
    Which chamber size?
    Recap:
    I have a Comp Cam's 222/224
    @.50, 112 LSA, .556, .560 lift. I have upgraded the valvetrain to
    complment this cam along with 1.8 rockers (not yet). I will also have a LS6 intake, ported throttle body or aftermarket, underdrive pulley, and long tube headers. Once the project is all together, I will get a custom tune. I do not mind a higher compression, but I also do not want to have to have it sky high either. I might have to "flycut" the pistions due to the 1.8 rockers. I want as
    much power as I can get!
    Patriot Performance offers LS6 bare heads for $745 a pair. That includes guides, seats and CNC chambers. They give you a choice on what chamber size you can have. It varies from, 59, 64, 68, 72. Which one?
    Keep in mind. No nitrous, no boost. This motor is going to be in a street driven car. I want as much horsepower as possible. In case you were wondering.
    Thanks guys
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    64.45 is the stock cc for the ls6 heads. Id shoot for 62 or 59. You can play with this to check your SCR: http://www.rosspistons.com/calculator.php
    I think the 1.7 rockers are fine. There isnt much need to bump up to the 1.8's. Make sure you get the proper size PR's. what gaskets are you going to use?
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    to much lift with the rocker arms if you go 1.8.
    you will have to fly cut the pistons
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Aug 2003
    Honolulu HI
    not to mention springs that will take the added lift.
    Minnesota
    1987 Trans Am
    The springs are good to .600. I think you guys have scared me away from the 1.8s.
    Ocala, FL
    1998 Formula
    59cc's is the way to go. Higher compression and cam's not big enough to cause p-v issues.
    Minnesota
    1987 Trans Am
    Can you guys give me a good idea on the horse power numbers with the different chambers?
  1. Question: 1-chamber mufflers?
    By ChevyLS1 in forum General Help
    Last Post: 04-27-2010, 01:21 PM
  2. one chamber exhaust
    By Darkrider02 in forum General Help
    Last Post: 01-01-2010, 09:04 AM
  3. plenum chamber
    By pipsterls1 in forum Internal Engine
    Last Post: 02-14-2008, 11:41 PM
  4. 1 chamber flowmaster?
    By jakef777 in forum External Engine
    Last Post: 11-13-2007, 09:28 AM
  5. Flowmasters 2-Chamber (2)
    By 991lez in forum Parts For Sale / Trade
    Last Post: 08-29-2006, 01:06 PM
