08-02-2006, 08:21 PM #1Junior Member
- Mar 2006
- Houston
Silver SS / Blue Z06- 1999 SS 2003 Z06
top strut bolt rusted and crumbeling
Top strut bolt is rusted and crumbeling, I put a socked on it but it just fell to pices but the threads are holding. Ideas on how to get the top bracket off?
I may just take it to a suspension place and have them do it. I didn't think washing under the hood hurt anything but I think water was getting in there and pooling around the nut.
08-04-2006, 01:16 PM #2
you mean the nut from the shock right? very typical. water gets in there from driving in the rain. i've had to torch them off. so, taking it somewhere and letting them deal with it is a good idea.
08-04-2006, 01:19 PM #3Jesus died to save you!
- North Olmsted, OH
Navy Blue Metallic- 2000 Camaro Z28
I used an impact wrent and took me about 1/2 per strut. Was a big pain, If you can't get an impat to grab then you can try cutting the shaft with a saw. Make sure that the spring is welll compressed so it doesn't jump at you when you cut it. Mine where rusted a bit again and I did this 3 montsh ago!
Good Luck
08-04-2006, 04:14 PM #4
what you do is fill that area with grease. that way no water can get in there and sit.
08-05-2006, 03:09 PM #5Junior Member
- Mar 2006
- Houston
Thanks I will fill it with grease. Good Idea.
08-05-2006, 11:07 PM #6
08-06-2006, 09:17 AM #7
98 Camaro>Rusted out Cats> will 2002s Fit?
By Intrepidman in forum General HelpReplies: 8Last Post: 04-30-2010, 02:52 PM -
Help: battery hold down clamp is rusted on
By Jeff3F in forum General HelpReplies: 5Last Post: 04-07-2008, 11:39 PM -
Looking at the Art and Beauty of Rusted Relics - Patina
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 04-24-2007, 02:20 AM -
rusted y-pipe problem
By Z28LS1 in forum External EngineReplies: 10Last Post: 01-14-2007, 01:30 PM -
some dude in a rusted out wagon
By whoss01 in forum Kill StoriesReplies: 23Last Post: 08-03-2006, 09:49 PM
