Results 1 to 16 of 16
Thread: Eibach install
    Shes Everything To Me Vols Fan's Avatar
    Landrum SC
    Eibach install
    Hey guys started my install this evening an hope to finish up tomorrow. I have a couple of questions. Should I reuse the rubber pad on the rear springs or get heater hose? Can anyone tell me any tips or tricks to getting the front shocks off? This is a Pro kit that is being used with 18" ZO6 wheels an revalved bilstien shocks that also will be going on tomorrow.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I would reuse the rubber unless you want it to sit alot lower in the rear.
    Spring compressor for the front
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Landrum SC
    Do I need the compressor to get it off the car or to get the spring off the stock shock? I am not reusing the stock stuff.
    Aug 1999
    No Where
    You need the compressor to get the spring off the strut.
    Junior Member at100plus's Avatar
    NJ
    2000 WS6 Trans Am
    Keep us posted and put up some pics of the install. I'm going to be installing mine soon.
    Houston
    Silver SS / Blue Z06
    1999 SS 2003 Z06
    I am doing mine now. MAN I AM stuck I have the front struts out but the nut on the top of the strut is rusted so it crumbled when I tried to put a socket on it. I need to get that top strut mount off or buy new. 160.00 for the top mount from GM. I don't want to cut it off but I don't have any ideas. I have new struts and springs just don't have a top mount. Ideas?
    Aug 1999
    No Where
    WD-40, and if you can't grab it with an impact. You're going to have to cut it off.
    Landrum SC
    What stock pieces will I have to reuse? I have new springs an shocks.
    Landrum SC
    Where can you get the new nut? I am having the same prob as CitationZO6.
    Member The Old Man's Avatar
    Mansfield Tx.
    98 Z/28
    The new nut comes with the new shock
    Landrum SC
    I'm getting my shocks used so don't know if I will get the nut. I did find out it is a M10x1.5 nut that you can purchase at any hardware or tool supply house.
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    Its a bitch, i did mine twice. Was new enough that the nut was fine and things went fairly smooth. Hard to get enough clearence to get them off. Spring compressors are definately needed. If you know someone with the actually machine they use to compress them its much easier.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    you're putting prokits... you better reuse the rubber to go on top of the springs... otherwise, you'll have 0 suspension travel, and your springs will actually be the bumpstops. the Heater hose is good for stock springs so you get an extra 3/4" drop. remember, you'll be getting a prokit drop + 3/4" drop on the rear (too much)
    Eugenio_SS
    Houston
    1999 SS 2003 Z06
    Any one use the heater hose on the bottom of the rear springs to keep from metal on metal contact?
    Landrum SC
    Quote Originally Posted by Eugenio_SS View Post
    Heater hose mod is address in this reply.
    Houston
    1999 SS 2003 Z06
    I am asking if any one used heater hoes on the BOTTOM of the rear spring to keep from metal on meal contact? You know between the spring and the axel shaft? I didn't want the spring perch to rub away the powder coating on the spring which leads to rust. Which I am having a rust problem with my SS. One winter in Colorado and one in New York will put about 10 years on a car, but hauling a$$ on the mountain roads and t tops off down broadway made it worth it.
  1. Question: Eibach's
    By Whitefish in forum Suspension and Handling
    Last Post: 04-02-2013, 10:11 AM
  2. Eibach Pro kit
    By stew215 in forum Parts For Sale / Trade
    Last Post: 04-01-2012, 07:54 AM
  3. Eibach Pro Kit
    By RS_SS69 in forum Parts For Sale / Trade
    Last Post: 07-06-2008, 07:56 PM
  4. New Eibach pro-kit!
    By bwinch in forum Parts For Sale / Trade
    Last Post: 06-12-2006, 01:46 PM
  5. Eibach
    By 1 badblack transam 01 in forum Suspension and Handling
    Last Post: 10-17-2005, 05:50 PM
