    Jun 2006
    1994 Trans Am GT Convt.
    Removing RH side manifold
    I have an exhaust leak on the passenger side right around the manifold, but i can't pinpoint where exactly it is. Ticks pretty good when you first start it up, but goes away after it warms up and expands. Was wandering how painful it is to replace them and/or would it be better to just put some headers on it. Can i get headers or even the manifold on with the engine in the car, because it looks pretty tight?
    Martinsville, VA
    1994 25th Anniversary T/A
    Gaskets aren't that bad to do.(I've changed mine four times) Put a set of headers on and haven't changed them since. Yes headers can be put on with the motor still in the car.
    Junior Member Schweet97Z's Avatar
    Danville, PA.
    Mystic Teal
    1997 Camaro Z-28
    r you sure its not piston slap that your hearing? if your sure its an exhuast leak i would def. do headers while you have the manifold off. you will like yourself better for doing so
    LA
    Grey
    2010 Camaro 2SS/RS CGM
    you can, though its a pain, you have to take off the alternator.
    Danville, PA.
    Mystic Teal
    1997 Camaro Z-28
    you have to take the alt. off for everything u do on this engine lol. its a matter of 3 bolts and a plug. its not hard at all.
  1. Removing side molding
    By Y2KPewterSS in forum Appearance Section
    Last Post: 06-07-2011, 08:20 PM
  2. Removing Side Vents
    By ls1camino in forum Appearance Section
    Last Post: 03-24-2010, 06:59 PM
  3. WTB: C6 Driver Side manifold
    By JAX04 in forum Parts Wanted / Trade
    Last Post: 04-16-2009, 05:40 AM
  4. Removing The SS Side Badges Question
    By RustyCamaro in forum Camaro / SS
    Last Post: 12-10-2007, 06:43 AM
  5. Removing Side Moldings
    By EightBall in forum Appearance Section
    Last Post: 11-27-2007, 02:10 PM
