Results 1 to 11 of 11
07-31-2006, 08:48 PM #1
coolant light on, full on coolant
Hey guys im having a problem with my coolant light, it keeps popping on everyonce in a while, and when i go to put coolant in it, its pretty much fool. could there be a bad sensor or something or an electrical prob? anyone know if this is common or not? thanks for the help
oh ya its formy 99 ws6
07-31-2006, 08:49 PM #2SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
Get used to it, change the sensor and hope it lasts a while, or unplug the sensor and live without the light altogether. If you really ant, you can pull it out and try to clean it up, it's just a few inches down from where you fill the rad up.
07-31-2006, 10:05 PM #3Member
- Jun 2006
- Bakersfield, California
red- 1959 corvette
Yeah, and then your change oil light will come on after you just changed the oil.
08-01-2006, 12:43 AM #4
yeah coolant lights tend to pop on and off once in a while. But if it's a recurring problem, could be the radiator cap not holding the pressure anymore and sending too much coolant back into the overflow.
08-01-2006, 06:19 AM #5
mine used to come on and off gradually... now it stays on all the time.
annoying at times... i think im going to unplug the sensor
08-04-2006, 11:02 AM #6Junior Member
- Dec 2005
- Huntsville, AL
Black- 1999 WS6
Call Billy Graham Salvage, 205-668-1169,,, He'll sell you one for about 15 bucks and reinburse or send another if it don't work. I did and my light has not come back on.
08-09-2006, 05:24 AM #7Member
- Virgina
Black- 98 Trans Am
Mine just started too....! Is this a "dealer only" item new?
08-09-2006, 05:35 AM #8Member
- Jul 2006
- jacksonville nc
red- 1995/2002 camaro z28's
my lights been on for a while, i figure if my temp is where its supposed to be the light doesnt matter much
08-09-2006, 05:40 AM #9Member
- Jul 2005
- commerce twp michigan
try bleeding it. Air in system
08-09-2006, 09:33 PM #10Member
- Tulsa,OK
Quick Silver- 2002 Z06
Mine did the same thing and I replaced the sensor and have not had a problem since. The above options of cleaning, and checking the cap are the most common fixes if replacing is not an option. Or replacing does not fix it. I don't agree that it will happen over and over my car has 171,000 and it has only happened once.
08-10-2006, 12:26 PM #11
hey guys i havent had this problem but i did with the change oil light after i changed my oil so i did something i never do check my owners manual lol, and the fix was right in the manual after you change the oil you have to reset the oil change light, by holding in your trip button for more than 30 seconds i think it was but i did this and has a problem since, i mean i was reving the engine and everything thinking maybe the oil hadnt got up to the oil light yet lol, i was glad i decided to actually read my owners manual. lol may not hurt to check your on this also. anyways good luck
thanks'ray
Low Coolant Light
By BWA2110 in forum External EngineReplies: 3Last Post: 05-03-2009, 04:27 PM -
Help: Need pic of coolant pump weep hole (Coolant Leak)
By Sweet Chops in forum General HelpReplies: 13Last Post: 04-20-2009, 07:14 PM -
Loosing Radiator coolant and milky colored coolant... what to do?
By JehalinTA in forum General HelpReplies: 23Last Post: 06-19-2007, 07:28 AM -
Coolant light...coolant level full.
By SR71 in forum General HelpReplies: 4Last Post: 01-08-2007, 09:35 AM -
ls6 intake coolant plugs or extra front coolant pipe?
By mikes ss in forum External EngineReplies: 3Last Post: 12-03-2005, 04:13 PM
