Results 1 to 3 of 3
    Feb 2006
    Chicago, IL
    2004 Pontiac GTO
    Shift Solenoid Stuck On
    I have the code 0757 P0757 (Shift Solenoid B Stuck On) How bad of problem is this? Can I drive it for a few days without destroying the tranny? How big of a job is it to fix?
    Thanks for the help.
    Senior Member
    Jacksonville, FL
    Shift solenoids are not hard to replace - they're in the pan where the valve body is. Personally I wouldn't drive it, got 3rd and 4th gear? - you under warranty? Sometimes people get this code after a high TC install and can take care of it with tuning. You can also try resetting the PCM (not sure on your car but disconnecting the battery for a while will probably do it) and see if it comes back. Think there was a TSB on it for the F-cars too, saw it on another board somewhere - I'll try and find the number for you, maybe you can google it.
    Senior Member
    Jacksonville, FL
    Found it - don't know if it applies to your car - just for info.
    DTC P0757 set, SES illiminated, poor performance of transmission, transmission slipping (Clean trans valve body and case oil passages of debris) #01-07-30-038B - January 26, 2004.
  1. Help: WS6 Shift Solenoid Code P0757?
    By PDempsey in forum Automatic Transmission
    Last Post: 05-20-2013, 03:50 PM
  2. Replies: 26
    Last Post: 09-30-2012, 09:40 AM
  3. Question: 4L60-e 1-2 shift solenoid
    By Butch2000 in forum Automatic Transmission
    Last Post: 03-23-2010, 08:33 PM
  4. Shift Solenoid Issue
    By TransAm11973 in forum General Help
    Last Post: 09-30-2009, 12:18 PM
  5. Shift Solenoid A code
    By NH Camaro Z28 in forum Automatic Transmission
    Last Post: 10-03-2005, 07:34 AM
