Results 1 to 13 of 13
    Compulsive F bomb dropper sgt0704's Avatar
    yuma arizona
    1998 Z28
    AHHHH!!! i blew up my monsoon amp.
    i was trying to hook an amp to the rear 8"s that i installed a while back, well, instead of putting the speaker wires from the amp to the 8's it went to the monsoon amp instead. the fucker started smoking and everything.
    so my question is, how do i wire the speakers, to run just off the head unit? i was looking at the amp wiring diagram, could i just wire the speaker feed lines to the same speaker's return line?
    Rock-n-Roller White Rascal's Avatar
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    I would run all new speaker wires but that's just me.
    The White Rascal SOLD
    Crank up the drums, crank up the bass,
    Crank up my Les Paul in your face!
    yuma arizona
    1998 Z28
    that wasn't the question. i'm not ready to dig that far into it yet.
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    Can you explain what "feed lines" and "return lines" are? In my 30+ years of dealing with car stereo I've never heard speaker wiring described using these terms.
    yuma arizona
    1998 Z28
    sure, looking at the wiring diagram, for the amp, and the "pin" for the plug in, it shows "right rear feed line" "right rear return line" etc... i'm just reading it off the guide i have.
    yuma arizona
    1998 Z28
    i just want to beable to run the speakers off the head unit. how can i do that for the time being, with out running new speaker wire all over the car. after hacking off the amp adapter, how do i hook the wires up to get them to play?
    p.s.
    i have no intentions of going back to stock.
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    I'd have to see this guide you have. The only time I've seen "send" and "return" used for signal pathes is the FX loop in a guitar amplifier.
    If you had a multimeter with a continuity checker you could use the process of elimination to determine which wires are which.
    I still think new wiring is the way to go. The factory wiring is on the small side. That and you wouldn't have any splices in your speaker wires either. I'm a purist when it comes to my audio systems. I like to go with larger guage wires and no splices.
    yuma arizona
    1998 Z28
    i'm not ready to dig that far into it yet. i'm not doing comps or anything.
    yuma arizona
    1998 Z28
    i just got it.
    Member Wulfe13's Avatar
    St. Louis, MO.
    2000 Pontiac Trans Am WS6
    I was under the impression that you can't just run speakers off the head unit in a Monsoon system.
    I replaced EVERYTHING in mine...
    Alpine CDA7998 HU
    Infinity Kappa Perfects 6.5 components in the doors.
    Infinity Kappa Perfects 6.5 Coaxials in the sail panels.
    Infinity 10" Perfect sub, the best one they make... I'm changing to an Alpine Type X soon, if I can't get the sub to sound better...
    Infinity 500 watt 4 Channel.... Changing that soon too... shuts down too soon. Not loud enough.
    Infinity 1500 watt Mono block.... This thing is BADASS!
    and a Half Farad Cap and all new wires(all Monster Cable).
    But this thing retailed around $3500. If I hadn't gotten most of it for free, I wouldn't have gone that high end.
    I put together a system for my brother that retailed for about $1700 and it sounds better than mine currently. That's why I'm thinking of changing the sub and four channel amp....
    Oh and I can still use my steering wheel controls.
    yuma arizona
    1998 Z28
    i got it wired of the HU.
    Austin, Tx
    Black/Black
    2000 Trans Am WS6 A4
    you would basically have to take out the amp and use a special wiring harness (I've seen them before,) that just directly connects the wires that go INTO the amp, to the wires that were supposed to come OUT of the monsoon amp...
    no big deal, other than your headunit will probably shit bricks when it sees a 2ohm load on all four channels...
    do yourself a favor, and keep those gains down..
    yuma arizona
    1998 Z28
    Quote Originally Posted by ScrapMaker View Post
    i got it wired off the hu. none of the speakers are two ohms. they've all been replaced. the only ones that are off are the 8's there 8 ohms. i haven't wired them to an amp yet. still working on it.
  1. ahhhh
    By saucycrossover1 in forum External Engine
    Last Post: 04-04-2011, 12:19 PM
  2. Ahhhh
    By GTP231 in forum Almost Anything Goes
    Last Post: 10-23-2009, 11:28 AM
  3. Ahhhh Spiders!!!
    Last Post: 08-20-2007, 10:57 PM
  4. Frustrate heads and cam swap!!!!!ahhhh
    By NightRiderZ in forum General Help
    Last Post: 07-11-2007, 05:46 PM
  5. ahhhh t-56 help!!!!anyone
    By knger in forum Western Members
    Last Post: 10-04-2006, 02:18 PM
