Results 1 to 10 of 10
    Jun 2006
    Bakersfield, California
    1959 corvette
    Cam, Intake, or headers with ypipe?
    I was wanting to get your opinion on what I should do next, cam, intake, or headers with offroad y. What will be my biggest gain for the buck, the headers with y are pretty close to the same as the cam.
    My mods on the 99 FORMULA
    Whisper lid, K&N, B&M Short Throw, CAI, Magna Flow Exhaust, UMI torque arm, FT LT hdrs, ORY, dual cutouts, 4.11 Gears, BMR SFC, BMR MSB, BMR lower control arms, Poly motor and tranny mounts, 575/568 232/227 111 lobe cam, Taylor wires, ngk tr55s,1 10in. JL W3 for beat.
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Headers and Y first to support the Cam & intake better.
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    Yep.........gotta be able to get rid of the air that you want to stuff in their first.........otherwise it's kinda like being constipated.....lol
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    agreed. there are certain trends to follow when modding. You can throw a cam and intake in, but the car isnt going to run as strong as you hoped for because your exhaust is a restriction. If the choice is either or, then Id go for the exhaust first, then follow it with the intake and cam and a tune.
    tx
    2001 Trans Am
    Agree with the fellows. The exhaust is the first thing you should do. Gottoa remove remove the factory restrictions.
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    yup exhaust is the best first
    Jun 2006
    1959 corvette
    Much appreciated, now which headers gain the most HP. I heard pacesetters with offr y gain about 20-25 rwp and are supposibly the easiest to install. However I would be willing to go through some hell if another set will gain for sure around 30 rwp. The pacesetters are pretty resonable as well. Also, is it worth the money for coated ones, ive heard it only reduces temp by a couple of degrees, and that the main benifit is they wont show rust spots as fast.
    Aug 2003
    Honolulu HI
    best of the best...QTP, Kooks or Stainless Works. All stainless. Most of us go with coated because of our budgets or some other instances. I havent seen a back to back dyno by swapping from abc headers to xyz headers and picking up a gain. However, I think I did see one somewhere with qtps and comapring its gains to others.
    Jun 2006
    1959 corvette
    Id like to see the number differences and price differences.
    central wisconsin
    most LT headers are comparable for HP gains, but you should look into ground clearance and ease of install as that varies from brand to brand........some think it is worth it to get coated, some think it is a waste. It does help, but I don't know if it is worth the money or not, just a matter of opinion.
  1. Kooks headers and ypipe
    By Kavslayer in forum External Engine
    Last Post: 06-19-2008, 06:12 PM
  2. Headers/ypipe w/ borla cat-back
    By Whiteboycntdnce in forum External Engine
    Last Post: 07-01-2007, 07:34 AM
  3. LS1 Pacesetter Headers Ypipe
    By sammy burks in forum Parts For Sale / Trade
    Last Post: 07-09-2006, 08:29 PM
  4. Headers & Ypipe
    By 99blueZ in forum External Engine
    Last Post: 06-08-2006, 09:29 AM
