07-23-2006, 07:52 AM #1SStatusGuest
ever heard of drilling a hole in the headers for dyno tune?
I'm getting a dyno tune next week and the guy i talked to said they regularly drill a hole in one of the headers to insert the sensor or whatever. He said this is to get the most accurate reading. Hes said its a 75 dollar charge and then they weld the hole closed when they are done. is this complete BS or do people do this?
07-23-2006, 07:55 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
He is talking about adding a wideband sensor before the cats. Yes that is accurate. But most don't do it. And just stick the sensor in the tailpipe.
If he still wants to do it, don't have him weld it back up. Have him install a bung and cap it off. This way if you ever want to run a wideband you can.Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
07-23-2006, 10:19 AM #3
good idea about the bung
07-26-2006, 01:24 PM #4Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
75 is far too much. it should be about 10 bucks for the bung(if that) and 20-30 to weld it in. depending on the shop. Id suggest you have a muffler shop do it for ya, then take it to him so they dont overcharge you. That or if he's tuning just WOT, then he can use your narrowband bung and place the sensor in there. much easier since he isnt using them to tune
just be sure to unplug and seal the narrowband if he doesn so it doesnt get exposed to fresh air while reading. could throw it off later.
08-04-2006, 10:57 PM #5
Ed I find myself agreeing with you all the time! I'm just wondering WHERE he would put ONE. I think if he's going to do that he may as well do it in both headers and then you could add dual sensors down the road. If you put a wide band in ONE header wouldn't you be tuning that bank and assuming the other bank is exactly the same when it may in fact be richer or leaner. I think that's a good argument for the tailpipe method because you're reading a mix of both banks.
Michael
In GA waving from '02 C5 LS1, Z51, D1SC, 60lb injectors,RPM level 5-4L60E, 3:42, Yank 3600, QA1-12 ways, MTI long headers, high flow cats, Borlas, Wilwood, 603rwhp, 542rwtq.(DynoJet 248-C) [email protected] on street tires, Race Weight 3,640 lbs
08-05-2006, 09:32 AM #6Senior Member
- Aug 2003
- Honolulu HI
then put it in the Y pipe where they both merge so you're getting a more accurate afr since you're both banks are mixed.
08-05-2006, 11:56 AM #7
drilling a hole in the Y pipe before the muffler?
By thiscatiskool in forum External EngineReplies: 20Last Post: 03-16-2009, 03:50 PM -
hypertech tune erase my dyno tune?
By Z28LS1 in forum Computer & TuningReplies: 3Last Post: 02-02-2009, 06:31 PM -
whats the diff with a full dyno tune and a street tune?
By Justin23454 in forum Computer & TuningReplies: 6Last Post: 12-04-2007, 06:31 AM -
Anybody ever heard of these HEADERS??
By 9t8z28 in forum External EngineReplies: 21Last Post: 02-20-2007, 03:04 PM -
Any1 heard or been to this tuner/dyno
By silver04gto in forum Computer & TuningReplies: 1Last Post: 07-21-2006, 04:58 AM
