    Chris01SS
    Holland, Michigan
    Black Onyx
    2001 Chevrolet Camaro SS
    Another Cam Question
    I own a 2001 SS Camaro. I know there is a difference in the cams from the 1998 LS1 and the 2001 LS1, right? If so what is the difference? Would it be worth my time to put a 1998 stock Corvette LS1 cam in my 2001 Camaro SS LS1? Would I see more ponies? Anything I might need to change to make it function correctly/give me more more ponies?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    1998 - 2000 Fbody
    202/210 int/exh @ 0.05" duration
    0.496" / 0.496" int/exh lift
    116 LSA
    2001 - 2002 Fbody
    197/207 int/exh @ 0.05" duration
    0.467" / 0.479" int/exh lift
    116 LSA
    you just won't get anything out of it. here' the LS6 cam
    2001 LS6 cam
    207/217 int/exh @ 0.05" duration
    0.525" / 0.525" int/exh lift
    116 LSA
    it's more in the heads and intake, than the cam, where the Z06 got it's power from.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    yeah, it's just not worth the trouble.
    mrr, you need to upload your sig pics to ls1 since the change to the new version
    '99 Z28 It's got the BADASS mod
    IT'S FOR SALE here:
    http://www.ls1.com/forums/showthread.php?t=70562
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by oneBADDz View Post
    i know, i'm just lazy. have to fit the dimensions as well. plus, i'm not sure if i can add two banners. have to consult with ed.
    Chris01SS
    Holland, Michigan
    Black Onyx
    So the LS6 cam will give me more or judt go with a after market? I wont get anything out of the 98 Vette cam at all, or so little it wont make a difference?
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by Chris2001SS View Post
    nothing with the 98 vette cam, and little out of the LS6 cam. just go aftermarket.
    Vienna WV
    98 Trans Am
    How much then for the Hot Cam?
  1. speedometer question + top speed question
    By Krazy351w in forum General Help
    Last Post: 06-21-2007, 05:51 PM
  2. HPIII question (not the same old question)
    By slims00ls1z28 in forum Computer & Tuning
    Last Post: 06-01-2007, 04:55 PM
  3. 97 Bird Headlight question also engine noise question
    By Zapper2003 in forum General Help
    Last Post: 12-13-2006, 03:03 AM
  4. Speedometer question, RPO question
    By acrylicophobia in forum Firebird / WS6
    Last Post: 11-02-2006, 07:08 AM
  5. Sex Question spinoff- PORN QUESTION
    By egaian in forum Almost Anything Goes
    Last Post: 07-26-2006, 03:07 PM
