Results 1 to 2 of 2
07-17-2006, 08:06 PM #112 Pounds
- Apr 2006
- all over
Silver- 95 Z
lower compression with gaskets?????
-i heard that you can lower compression by changing to a thicker head gasket, i want to lower the compression so it will be safer to run more boost. i have a lt-1 and i want to run 14 lbs. i am running 9 right now
-do you think i would blow my head gasket by running a thicker one. yet again this is just what i have heard.
07-18-2006, 04:12 PM #2
that would be a cheap way to lower the compression. but, the thickest gasket you could get would be .051". i think stock are .045". about .1-.2 less compression. every .006" = 1cc. plus, the thicker the gasket, the more chance of popping it if you get into detonation. honestly, the best way is dished pistons and a thinner gasket. this pushes the mixture closer to the piston instead of the chamber.
compression
By emotionalpiracy in forum Internal EngineReplies: 5Last Post: 05-29-2008, 11:16 PM -
compression
By 00ssls1 in forum Internal EngineReplies: 0Last Post: 05-28-2008, 07:18 AM -
Question: How would you lower compression on an LS1?
By SVG210 in forum Internal EngineReplies: 5Last Post: 04-16-2008, 06:52 PM -
Compression
By gashkerwin in forum Internal EngineReplies: 1Last Post: 12-30-2007, 12:16 AM -
Bigger heads lower compression
By Naf in forum GTOReplies: 7Last Post: 04-04-2007, 10:35 PM
