Results 1 to 17 of 17
Thread: SES Light Problem
09-07-2005, 03:27 PM #1DiPeRRi 99Guest
SES Light Problem
Im getting 2 SES codes, and i was wondering if anyone knew what was setting them off. They are P1133, and P1153. Its says for both codes "Manufacturer Control Fuel/Air Metering". I was getting 8 codes in total, but i installed 02 sims, and that seemed to take care of the cat effeciency and 02 heater circuit codes that were coming up.
I have SLP headers and catback, underpulley, lid and cold air... Anyone have any ideas?
09-07-2005, 03:32 PM #2I went to Playboy Mansion
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
My guess would be the fuel pump could be getting weak. Our fuel pumps are not the best because they are in the gas tank and when we get under a 1/4 of gas it puts strain on the pump to get the gas to the engine. Its just a guess cause thats the onlything that has ever happened to my car.
10-04-2005, 08:58 AM #3NH Camaro Z28Guest
I recently had the same code shortly after hollowing out my cats.
Data Code: p1133
Coolant Temp: 167 Deg F
Short Term Fuel Trim 1: -3.1%
Long Term Fuel Trim 1: 10.2%
Short Term Fuel Trim 2: 3.1%
Long Term Fuel Trim: 10.2%
Engine Speed: 65 MPH
RPM: 1670
MAF: 3.32
MAP: 13.9
Throttle Angle: 10.6%
Any Sugggestions? MAF Sensor Faulty?
10-04-2005, 10:53 AM #4
its a code for insufficient switching of the o2...exhaust leak possibly near the sensor...has nothing to do with the maf in most cases.
10-06-2005, 05:04 AM #5NH Camaro Z28Guest
This was a suggestion by one of the guys I work with. At Auto Zone, you can get anti-fowler threaded spark plug extensions. It will allow the o2 sensors to heat up enough to get a "reading" thus no code. It may even trick the vehicle thinking that the cats are still there because it's only sniffing the exhaust, not getting the full flow. We're going to try it today. Wish me luck.
10-06-2005, 05:27 PM #6tank99_999Guest
did it work
10-10-2005, 05:39 AM #7NH Camaro Z28Guest
Unfortunately it did not work. I now have the P1153 and P1133 codes. It seems to happen when the vehicle it cold based on the freeze frame data. I checked for leaks and there were none found. Anyone know if O2 sims will correct the condition?
10-10-2005, 07:58 AM #8Senior Member
- Jul 2005
- Jacksonville, FL
02 sims are for the post cat 02's only, 1133 and 1153 are precat 02 codes.
10-12-2005, 03:25 AM #9NH Camaro Z28Guest
I called over to a Chevy dealership that I do a lot of business with. I found out that the left side O2 sensors are the same (post and pre cat sensors) along with the right side. So, I'm going to switch the O2 sensors front to back and the code should change. i.e good ones in the front, use the sims for the rear. Vehicle is happy.
10-13-2005, 02:41 PM #10Junior Member
- ST.PETERSBURG FL
PEWTER- 2001 TRANS AM WS.6
I Have the same problem its slow switicing in the pre cat o2's I also have SLP LT's ORY and no cat's O2 simms on the rear I have replaced the o2's and It didnt help? If you find something that works I sure would like to know.
10-15-2005, 06:16 AM #11tank99_999Guest
i herd that you use corvette rear o2 for the front
10-15-2005, 12:30 PM #12NH Camaro Z28Guest
I had the o2 sensors switched front to rear. If one of the sensors was bad, it should throw a different code I would think. After 4 drive cycles, the light came back on- Code p1153. I checked the freeze frame information and I'm still getting odd Short Term Fuel Trim readings. I work at a Subaru Dealer, we had a STI once that kept throwing a rear o2 sensor code. We put in a new rear o2 sensor and the light came back. We installed a MIL eliminator and still the light came back. Per the Subaru Manual, we had to replace the ecm. The light has been out since the ecm has been replaced. Granted I know these are different animals, but I can't figure out why the Short term fuel trim keeps acting oddly. Any suggestions?
10-17-2005, 04:56 AM #13NH Camaro Z28Guest
After consulting with one of the tech at my work, he figures that the front O2 sensors are not heating up enough to get a correct reading or the fuel trim os going too far out of range for the computers liking. Anyone know a good programmer then?
10-17-2005, 06:13 PM #14tank99_999Guest
can a programmer make the 02 get hotter
10-18-2005, 06:10 AM #15NH Camaro Z28Guest
It can't make it hotter, but it may allow for greater fuel trim range. I'm not getting a lean or rich code. My chip may have something to do with the light. The chip may be allowing a greater fuel range that the ecu does not like. My car runs great, just having the light come on is a pain in the back side. I haven't had a P0420 Cat inefficiency code which may be chip related as well. Although we work only on Subarus here, my techs out back cannot find any reason the light would come on based on what their monitors show for A/F ratios. Anyone have their ecm reprogrammed?
11-23-2005, 07:06 AM #16NH Camaro Z28Guest
Hey guys. Something odd happened. Now since it's about 40 degrees out on a regular basis now, my SES light went out for my p1153 and my p1133 codes. Odd huh?
07-25-2006, 01:24 PM #17Junior Member
- May 2006
- California
Chameleon- 1998 Pontiac Trans Am
I have the same P1153 code. Do you thing an engine tune will help? Can I delete my rear cats from the computer and get rid of the problem? I also have O2 sims in the rear and tried replacing them with no luck as well.
light problem
By b&dsta in forum General HelpReplies: 8Last Post: 02-06-2009, 10:04 PM -
light problem please help!
By 98silver t/a in forum General HelpReplies: 7Last Post: 08-21-2008, 03:13 AM -
SES light and problem
By insane4fbodys in forum General HelpReplies: 2Last Post: 12-08-2007, 08:27 PM -
Coolant light problem
By cobrahunter in forum External EngineReplies: 3Last Post: 08-05-2007, 11:51 PM -
interior light problem
By u69038 in forum Stereo and ElectronicsReplies: 2Last Post: 06-15-2007, 06:36 PM
