Results 1 to 14 of 14
Thread: Z28 Alignment
07-14-2006, 10:44 AM #1
- Apr 2006
- Austin - Texas
Silver- 1999 Camaro Z28
Z28 Alignment
Hi,
I'm hoping that someone can help, I've got a 99' Z28 Camaro European spec and it needs the alignment sorted. However being a rare car in the UK none of my local tyre places know or can get hold of the alignment details - even from UK Chevrolet! Does anyone know what the angles should be for the camber, caster, toe-in etc?
Any help would be much appreciated.
Thanks Gareth
07-14-2006, 03:21 PM #2
factory specs are as follows for left and right.
camber 0.50* +/- 0.50*
caster 4.50* +/- 1.00*
toe 0.00 +/- 0.10*Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
07-15-2006, 01:33 AM #3
- Apr 2006
- Austin - Texas
Thats a great help, thanks
07-17-2006, 08:09 PM #4
- Jun 2002
- Montreal, CANADA
humm hummm
stock specs are:
camber: 0.0' to +1.0' (correct)
caster: +4.3' to 5.3'
toe: 0" +/- 1/32"
try to get:
toe: 0"
caster: +4.5'
camber: as much negative as possible... if you get -0.5' it's great... (goal is to get a bit on the negative side, if possible... otherwise, get lowest value, given you get the above ones.)Eugenio_SS
07-18-2006, 02:20 PM #5
0.00* to 1.00* is the same as 0.50* +/- 0.50* -- +0.50* + 0.50* = 1.00* and +0.50* - 0.50* = 0.00* you have the nominal number (+0.50*). then you have the range allowed (+/- 0.50*)
but, you are correct on the caster. it's actually 4.80* +/- 0.50* instead of what i posted.
07-19-2006, 04:37 AM #6
ok, just looked in my hunter alignment machine database. here are the correct specs:
camber 0.40* +/- 0.50* that's a range of -0.10* to 0.90*
caster 4.80* +/- 0.50* that's a range of 4.30* to 5.30*
toe 0.00* +/-0.20* that's a range of -0.20* to 0.20*
07-19-2006, 04:39 AM #7
07-19-2006, 04:46 AM #8
07-19-2006, 07:30 PM #9
- Jun 2002
- Montreal, CANADA
toe can be measured in degrees or inches... depends on preferences.
My specs were closer, though
07-19-2006, 07:32 PM #10
either way. the specs are now located at the top of this forum in a sticky. are you a moderator yet?
07-21-2006, 12:12 PM #11
In regards to your new sticky:
Here is a decent link/reference to basic alignment/suspensions queries;
http://www.angelfire.com/my/fastcar/suspension.html
07-21-2006, 07:05 PM #12
well, except for the alignment reccomendations, it's neat stuff.
07-26-2006, 04:26 PM #13
07-26-2006, 04:29 PM #14
Alignment
By ls1camino in forum Suspension and HandlingReplies: 1Last Post: 09-07-2011, 01:53 PM -
Wheel Alignment Guide - DIY Alignment
By Ed Blown Vert in forum Almost Anything GoesReplies: 5Last Post: 08-06-2009, 03:30 PM -
do it yourself alignment.....help....
By redz284u in forum Suspension and HandlingReplies: 4Last Post: 03-08-2007, 04:21 PM -
LT1 alignment
By Chad97z in forum LT1Replies: 10Last Post: 08-05-2006, 03:15 PM -
Anyone do your own alignment?
By jrummi in forum Suspension and HandlingReplies: 3Last Post: 09-14-2005, 08:14 PM
