Results 1 to 3 of 3
Thread: .250 spacer
07-09-2006, 10:54 AM #1Member
- Jul 2006
- Vancouver,B.C.,Canada.W.Coast
Navy Blue Metallic- '99 T/A WS6 M6
.250 spacer
...Can a 1/4" [.250] spacer be used with the stock wheel studs ???
...rear only needed.
07-09-2006, 12:12 PM #2
sure. check to make sure you have at least three full turns on the lugnuts to be somewhat safe.
07-09-2006, 12:48 PM #3Member
- Jul 2006
Thanks for the quick reply..only 3 full turns you think...another person said at least 6 full turns..[should have had longer studs put in these axles..I have 31 spline ones from a local rear-end company.]...I thought that was a little much, considering some of the things I have done in the past with other cars.!!....BTW...I already have some 1" Billet wheel adapters I was using with another set of rear wheels, but I really need 1/4" or maybe a touch more clearance really..when I got the adapters my plans for another set of wheels changed..sorta wish I had 1/2" adapters instead.....[ mrr23...I added 10% in my tuner and all seems well..runs better.]
Question: Tb spacer
By 98maro in forum General HelpReplies: 5Last Post: 03-27-2010, 02:30 PM -
18 x 8 Wheels, Need help with Spacer
By 6speedTAthistime in forum Wheels and TiresReplies: 3Last Post: 08-14-2009, 05:44 PM -
Wilson Manifold Carburetor Spacer - Spacer Science
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-24-2009, 07:00 AM -
Removing the TB Spacer on '98 LS1
By dj_phaedrus in forum External EngineReplies: 4Last Post: 12-07-2007, 09:36 AM -
throttlebody spacer
By FreakV6 in forum V6Replies: 3Last Post: 08-13-2006, 04:59 PM
