Results 1 to 3 of 3
    SS and 3/S TT owner
    OBX, NC
    7-7-06 Test-N-Tune results.
    Hit the local track again this evening and made a couple of passes. The track was unusually busy. We had great air for the time of year so maybe more people came out. ~700 DA on the first pass. ~500DA on the second pass and the times reflected this better air overall tonight.
    1st pass once again my car spun the MT Radials ever so slightly off the line. Rest of the pass was decent hitting the gears properly, etc. 30 minute cool down after driving to the track.
    60' 1.620
    330' 4.788
    660' 7.501
    MPH 90.228<-------Really good air for sure.
    2nd pass after cooling down for an hour. My driver really put some heat in the tires and the car dead hooked off the line finally. We just can't catch a break though as a botched shift ruined what would certainly have been a mid/low 7.4x pass.
    60' 1.591
    330' 4.824
    660' 7.568
    MPH 89.700
    My driver said the car was pulling so hard off the line (relatively speaking I know) that he delayed the 1-2 shift hitting the rev limiter ruining the pass. The car sort of recovered but the extra .03 @ the 60' vs the 1st pass should have been good for at least .06 by the 660'. Oh well, once again it was not to be. I hope we get all these botched passes out of the way before some
    -DA air comes back around in the Fall/Winter. Then it's time to shoot for some low 11's in the 1/4 mile and see how far up that infamous SI list my car can make it. It's also time to get busy now taking another 300+ pounds off the car. Time flies when you're having fun. More updates to follow. Thanks for reading and see you at the track.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    good job. make sure to post in the ET listing.
    SS and 3/S TT owner
    OBX, NC
    I didn't think 1/8th mile runs counted.
  1. Results of my last tune session
    By SMWS6TA in forum General Help
    Last Post: 12-03-2015, 08:54 AM
  2. test n tune
    By racer426 in forum Drag Racing
    Last Post: 01-13-2008, 11:44 AM
  3. test results in, I made it! USAF - E6 (TSgt)
    By jrc1122 in forum Almost Anything Goes
    Last Post: 06-14-2007, 03:48 PM
  4. Post the results of your High Speed connection test
    Last Post: 10-18-2006, 04:38 PM
  5. Sniffer test results on an LT1?
    By thehemi in forum LT1
    Last Post: 11-07-2005, 08:08 PM
