Results 1 to 15 of 15
Thread: k and n fipk
07-07-2006, 10:54 AM #1
k and n fipk
would a kandn fipk intake system be good to use with a camaro ss with the hood scoop?...because i already have a whisper lid descreened maf and the cut out mod.........or just save the money and stick with the current hardware?
07-07-2006, 11:07 AM #2
I'd say stick with the current setup; I've got the fipk, and while it is said to have notable gains over aftermarket lids, no comparisons have ever shown anything conclusive. Besides that, the fipk really uglies up the engine bay, stick with a smooth lid, maybe consider a cold air kit to help with the FRA mod.
She's baaaaaccccck...
'02 Z/28 M6 Hardtop
07-07-2006, 12:58 PM #3
Go for some drag radials or some better bolt ons instead...
07-08-2006, 05:00 PM #4Member
- Sep 2005
- Sac
Mystic Teal- 01 Z28
07-08-2006, 08:53 PM #5We'll be back...
- THE SWAMP
Keep what you have and use that $ on something else.
07-09-2006, 09:23 AM #6Junior Member
- Mar 2006
- Gulfport
red- 2000 trans am ws6
MysticZ, You gotta be kidding 23hp from FIPk, I would keep the lid it wont be worth the $300 getting the FIPK, I know I have the FIPK and Kinda wish I just woulda went with a lid.
07-09-2006, 03:42 PM #7Member
- Sep 2005
- Sac
Mystic Teal- 01 Z28
Not kidding - dyno sheets below... car ran 12.13 @113 on just bolt ons in +1800 DA @ 3600 lbs raceweight ... keep in mind that the FIPK may be $300 - you should be able to pick one up for around $270 though - you're done once you have the FIPK, no need for an FTRA/SSRA/SLP Coldair.
Attachment 5583
Attachment 5584Last edited by MysticZ28; 07-10-2006 at 03:33 PM.
07-09-2006, 04:18 PM #8Junior Member
- Mar 2006
- Gulfport
I know i didnt gain nowhere near 23hp from mine maybe 10hp if im lucky, Iv never heard of anybody claiming that much from a FIPK, KN only claims 14rwhp with it, did you get a tune with ur fipk or did you just do a before and after dyno of the fipk. Congrates on the gain either way.
07-09-2006, 10:03 PM #9Member
- Sep 2005
- Sac
Mystic Teal- 01 Z28
Just before and after ... 3 pulls each time ... Highest pull to highest pull
07-10-2006, 08:02 AM #10
wow that makes me feel better about my K&N
i think it looks pretty cool too
i guess others have a diff opinion tho
07-10-2006, 01:53 PM #11
No way there's a 23 rwhp increase. Not unless your stock run was with a diaper shoved under the lid. Just dynoed a car at the shop with a true before and after from stock lid, baffles and all, to k&n fipk setup. Car dynoed 287.6 rwhp stock, 299.2 rwhp with fipk. That's just under a 12 rwhp gain. K&N claimed up to 18 rwhp on a dyno with simulated airflow, i.e. they used a big fan to make it seem like the car was going 60 mph... At best, with a simulated airflow and non-corrected numbers, you might see 23... but if so... well that's just crazy!
07-10-2006, 03:53 PM #12Member
- Sep 2005
- Sac
Mystic Teal- 01 Z28
Pulls were 6 weeks apart ... similair summer days SAE corrected, but the PCM had time to adjust to the FIPK.
Car was bone nuts stock, 8 weeks old, with about 1200 miles and 10 passes on the first session and just the FIPK, with about 1700 miles and 25 passes the on second session and no bullshit dyno tricks.
07-10-2006, 05:55 PM #13
This may be far fetched, but could the engine have actually broken in substantially between those 500 miles and 15 passes? I've seen lots of proof that when an engine wears, it can gain a good 10-20, any thoughts?
07-10-2006, 07:11 PM #14Member
- Sep 2005
- Sac
Mystic Teal- 01 Z28
Let me ask this ... you said you did back to back ... did you do them in the same day? If so, did you you disco the battery during the install?
07-23-2006, 04:18 PM #15SFL Drifters
- Jul 2006
- Florida
Pewter- 2002 TransAm WS6
you should just get the ultra z hood, it works better than the ss hood.
Question: knn fipk n bad mpg???
By 02blackz in forum External EngineReplies: 6Last Post: 05-30-2012, 12:25 PM -
K&n fipk
By 98Z28CamaroJG in forum Parts Wanted / TradeReplies: 0Last Post: 09-30-2010, 12:29 AM -
K&N's FIPK
By WhatUpWhatUp in forum External EngineReplies: 18Last Post: 03-06-2010, 10:20 AM -
K&n Fipk
By pinky93 in forum External EngineReplies: 13Last Post: 12-09-2007, 07:14 AM -
F/s K&n Fipk
By 1SICZ in forum Parts For Sale / TradeReplies: 4Last Post: 11-01-2006, 09:17 AM
