    Indiana
    2000 TA Built
    MONSOON@@@@@ please help easy question!!!!!
    hey guys, im buying a new head unit from best buy and i currently have 2 subs and a 1000 watt amp but the monsoon head unit wont power it correctly, my question is what all i going to be needed to be done in order for them to switcth head units???? is it a normal install with the monsoon system?????? my car is a 1999 and also....all they have to do is send my rca cables to the front headunit right????? thanks guys please help me i need this asap!!!!
    elk grove
    99 trans am
    to switch the hu all you need is a wiring harness and an install kit, since you said you bought it from best buy, they should have the correct harness for your new head unit. all you need to do is plug the factory wiring harness into the one you just bought, and put that into the back of your new hu. if your new head unit has the rca inputs on it, then yes all you have to do is run them from the amp to the hu. oh and another thing, your gonna need an intenna adapter that goes from the existing intenna into the back of the new hu so you can recieve radio stations. everything together should cost around 30 bucks.
    Indiana
    2000 TA Built
    you are one helpful sob......thanks!!!
    elk grove
    99 trans am
    no problem
    Junior Member tsench's Avatar
    Mississauga
    that easy
    Rock-n-Roller White Rascal's Avatar
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    If the guys at Best Buy can't figure out how to use your gear along with the POS Monsoon HU I don't think I would want them to even touch my car. What a bunch of morons they must be.
    The White Rascal SOLD
    Crank up the drums, crank up the bass,
    Crank up my Les Paul in your face!
    Junior Member jlhillery's Avatar
    Indiana
    2002 firebird
    This worked great for me.......I kept my original head deck and added a 10 disk changer.... then I hooked up a line level rca cord off one speaker and hooked the amp up mono to run my sub.... sounds great........
  1. Stupid VATS! Easy question
    By 173rdbrandon in forum General Help
    Last Post: 11-03-2010, 05:10 AM
  2. Quick and easy gun question...
    By nitrox28 in forum Gun's & Ammo
    Last Post: 07-12-2010, 09:00 PM
  3. Very easy question
    By crapyboy750 in forum General Help
    Last Post: 02-05-2009, 02:34 PM
  4. Quick and easy HP tuner question
    By Firebirdjones in forum Computer & Tuning
    Last Post: 02-26-2007, 02:27 PM
  5. Easy alter question...I hope
    By Transam388 in forum General Help
    Last Post: 09-22-2006, 01:50 PM
