    Member JattGunMan's Avatar
    cali
    2000 ss
    patriot perf cam 110lsa,232/230
    im lookin at a patriot performance cam 110 LSA, 232/230 Duration, 580/580 Lift for 279.99 which seems like a decent price i have about a 1000 dollars to spend and was thinkin about gettin this along with some lt even though i live in cali...what else should i look into when gettin the cam installed?
    A cam install will be about $1000 by itself if you do the install on your own.
    Valvesprings
    Oil pump
    Pushrods
    LS2 timing chain
    Cam
    You won't pass emissions with that cam in Cali.
    Lowered, HID's, tinted.
    Retired Outlaw Sum Bitch
    What are you trying to do? What are your goals here....
    This is my signature. It is mine. Nobody else has one like it.
    cali
    2000 ss
    originally i was lookin into a procharger setup but alot of people told me that i shoud try to build up my engine na and id be alot happier with it and then later on move up to the procharger...rite now im HOPING i can just payoff some smog guy but with my luck most likely not..overall just wanna quicker car to play with the big boys
    Junior Member Duke of Cruel's Avatar
    Jun 2006
    sweden
    red metallic
    1991 sierra cosworth
    Quote Originally Posted by JattGunMan View Post
    That cam is for a manual trans, but if it is a ls1 engine you must have pushrods and springs with any performance cam change. If your lifters are the ones where the wheel is free, you must change them too. Titanium retainers if you can afford them, they are worth the money.
    My advice for you is to find a good set of ls6 heads for around 500-600$
    and put them on with the cam, that would really let the air in the cylinder.
    Look around for prices, you could get a head/cam swap for around a grand, but remember to change the standard pushrods, they ar worthless for any more lift, and/or rpm. Also remember to get a decent tune up, and if it is ok, you might even pass smog inspection.
    It is more expensive to upgrade the ls1 heads than it is to buy used ls6 heads, that also have the lighter and better valves.
    Hope you can use some of this advice.
    DoC
    Jun 2006
    sweden
    red metallic
    I found this at ebay, you might find it interesting. It got all you need, besides
    gaskets and cam. http://cgi.ebay.com/COMP-CAM-GEN-3-L...QQcmdZViewItem
    DoC
  1. Question: What does 3800 Perf. Pkg (Y87) mean?
    By Superwoody in forum V6
    Last Post: 04-19-2010, 11:55 PM
  2. WTB Hi-Perf Cam
    By SleeperC5 in forum Parts Wanted / Trade
    Last Post: 06-23-2007, 02:45 PM
  3. where to find high perf. t56?
    By toneloc60 in forum Manual Transmission
    Last Post: 05-27-2007, 07:19 PM
  4. Evolution Perf. dyno day
    By SSmiley1906 in forum Eastern Members
    Last Post: 03-20-2006, 01:47 PM
  5. Replies: 0
    Last Post: 12-31-2005, 10:41 PM
