07-04-2006, 09:04 AM #1Junior Member
- Sep 2005
- Idaho
Red- 2000 Camaro SS
Will a rear end without traction control work on my car?
I have a 2000 SS with traction control. I might buy a 12 bolt moser out of a 1998 SS that has no traction control. Are they compatible? Or what mods do I need to make? I dont really care for traction control so someone please let me know.
07-08-2006, 11:51 PM #2
the rear will go right in. you won't have traction control anymore and possibly not ABS either.
07-09-2006, 01:41 AM #3ThaLS1KidGuest
Neither one of your ABS or traction control will work, but yes the rear will physically work.
07-09-2006, 02:11 AM #4
Can you just press the reluctors onto that rear?
07-09-2006, 02:57 AM #5ThaLS1KidGuest
Yes you can get them on to the axles but the rear end housing does not have the provisions for the sensors.
07-09-2006, 01:14 PM #6Sexy Motorhead
- Jul 2006
- Florida
Redline Kiwi Green/Black- 08'/02'/99'/97'/83'/82/81
The diff will fit right in. Obviously you TC will not. LS1Kid, all of the 4th Gen F-Bodies have ABS. He will be able to hook up his plugs up tp the 98s rear.
07-09-2006, 05:22 PM #7ThaLS1KidGuest
It depends on where/if the 12 bolt was set up for the sensors. If it is set up for a three chanel, which it sounds like it is, neither of his traction control or his ABS will not work. If it is set up for a four chanel then his stuff would work. And if it has no sensor holes then none of his stuff will work either.
three chanel=abs only (1 sensor on top of the pumpkin)
four chanel=traction control and abs (2 sensors, one on top of each axle tube just inboard of the backing plates)
The reluctor ring/rings are in different spots on the 3 and 4 chanel set ups.
Charlie, you need to find out if the 12 bolt is set up for 3 or 4 chanel. If you have traction control and abs you need a 4 chanel rear end for all of your stuff to work. A 3/no chanel set up will physically work in you car but your traction control and abs will not work.
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
wanted ls1 3.42 rear with traction control
By tjclt250r in forum Parts Wanted / TradeReplies: 2Last Post: 06-04-2008, 08:19 AM -
How to Mod a rear end for traction control
By camarojunky74 in forum DrivetrainReplies: 10Last Post: 10-23-2007, 02:35 PM -
Traction Control
By lonestarservices in forum General HelpReplies: 0Last Post: 05-06-2007, 04:31 PM -
stock TA rear end with Traction Control
By fancherfast in forum Parts For Sale / TradeReplies: 1Last Post: 04-03-2006, 11:18 PM
