Results 1 to 3 of 3
    Mount Pleasant
    1998 Camaro Z28
    Code p0480. help!!
    The SES code p0480 was detected in my car. I found out that it was a Cooling Fan Relay 1 Control problem. Does anyone have any knowledge on that?
    Senior Member
    Jacksonville, FL
    No experience with it - maybe you can find the answer at gearchatter.com.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    check the relay in the engine compartment fusebox for the fan relay switch. It's a huge metal box in there. Possible it's not plugged in all the way or dead so it's not switching you fan on. It's a $5 fix, just pull the relay, go to your local autostore and pick up a new relay switch, just bring it down with you to compare it
  1. Should I be getting a code?
    By dlacey82 in forum Computer & Tuning
    Last Post: 06-01-2011, 04:45 PM
  2. Help: P-308 code need help!!!
    By mfd#1 in forum GM Trucks
    Last Post: 10-16-2010, 12:24 PM
  3. SES code
    By Johns00Z28 in forum General Help
    Last Post: 08-28-2008, 04:04 PM
  4. 1LE code?
    By 5 ltr. beater in forum Suspension and Handling
    Last Post: 05-28-2006, 01:21 PM
  5. help!!ses code and what to do???
    By baseballss in forum General Help
    Last Post: 02-23-2006, 07:01 PM
