07-03-2006, 07:58 AM #1Junior Member
- Jul 2006
- tennessee
white- 1996 z71
problems with 1996 4L60e trans shifting
I have a 1996 Z71 truck with a 5.7 vortec 350 motor and a 4L60e transmission that has some shifting problems it will not shift and we pluged the computer tester up to the truck and it said it was a PO785 shift/timing solenoid malfunction we changed the shift/timing solenoid and did not fix it which we think the shifting solenoid is on the driver side but we are not sure if this one is it because there is two just alike.
The problem with the truck is when you first start out in the truck it works fine till it changes through all the gears then it will not downshift by its self you can downshift it manually from third to second but does not have 1st gear or overdrive. You can turn the truck off and let it sit for a while and it will do fine and shift up but not down without manually.. If anyone has any information to help with the problem we would really really appreciate it...
NEED HELPLast edited by acollins2187; 07-03-2006 at 08:07 AM.
07-03-2006, 08:01 AM #2Junior Member
- Apr 2006
can you give me the exact code its setting , and ill see if i can assist you .
megamax
07-05-2006, 06:35 AM #3Junior Member
- Jul 2006
- tennessee
white- 1996 z71
thank you the code was po785 but i got it fixed it was a 2/3 shifter solenoid .. thanks
07-06-2006, 07:57 AM #4Junior Member
- Jul 2006
- tennessee
white- 1996 z71
Need More Help
after changing the 2-3 solenoid the transmission worked fine for about 50 miles and now it has 1 and 2 gear but no 3 gear it trys to go in third gear but the rpm will go up but the transmission does not make the truck go any one got any answers if you do i would appreciate them very much..
07-06-2006, 08:04 AM #5Junior Member
- Apr 2006
3rd gear rev
1-2 second shift normal , then where the third gear shift should be the tranny neutrals , is my asumption of what your trying to say , And unfortunatly the is a mechanical failure , 3-4 clutch pack has burned or drum broken . to verify this unplu harness from tranny , attempt to drive , if the 3-4 clutch is bad the car will feel like its in first if its not bad it will be very slugish like in a higher gear , the default gear for the 4l60e with harness unplugged is third gear .
megamax
sorry to give bad news
Help: 4l60e problems not shifting to 2nd and 4th?
By cccullins in forum Automatic TransmissionReplies: 41Last Post: 05-13-2015, 11:01 AM -
Help: 2002 WS6 Automatic Trans W / Stall Shifting Problems
By Redrokit8 in forum Firebird / WS6Replies: 2Last Post: 10-10-2013, 05:39 PM -
Ratchet Shifting a 4l60e
By MudStainKILLA in forum Automatic TransmissionReplies: 29Last Post: 04-18-2010, 09:07 AM -
1995 Trans Am 4L60E shifting problem
By 1999TransAmWS6 in forum Automatic TransmissionReplies: 0Last Post: 08-30-2007, 06:30 PM -
trans shifting problems??
By jackmajic in forum Automatic TransmissionReplies: 4Last Post: 06-23-2006, 04:21 AM
