    Member Ripper415's Avatar
    NY
    2002 Camaro SS
    Question gas tank/gauge problems
    I wasnt sure where to post this topic but I figured this was as good a place as any. Basically when I'm driving around in my 02 SS it seems as if the gas gauge barely moves. But the next time I start the car the gauge goes down like an 8th of a tank. It's really pissing me off. For example, I'll drive to work (about 10 miles of highway cruising) and the needle will go down like 1 milimeter. Then I'll get out of work and turn the car on and the new reading on the gauge will be like a centimeter lower?! It cant be a gas leak because I'd definately smell it or see liquid spots under the car, and I dont. Also, another thing I noticed is that it seems to take a lot longer for the tank to get from full to half then it does to get from half to empty. I just got this car a few months ago and was wondering if anyone else had these problems too, or if theres some kinda defect with just my car.
    Senior Member
    Jacksonville, FL
    Sounds normal to me. My driveway is on an incline and it always reads higher pulling out - go to the store 8 miles away - restart and it's considerably lower. And yeah, it'll take a lot longer going from full to half, than from half to empty. Usually a bad sending unit will read full forever, then drop like a rock (if it does at all). Be nice to your fuel pump and don't let it fall below 1/4 - seen to many "ran low/out of gas and now my fuel pump won't work" posts.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Quote Originally Posted by Ripper415 View Post
    that is very common. with all cars. i just noticed it on my new car. Dont worry, maybe be easier on gas?nahhh, your all good.
    Junior Member dougcw's Avatar
    Evansville, IN
    2002 Trans AM WS6
    Because of the shape of the tank (for the T-tops) 5/8 is actually 1/2 a tank on the f-bodies. I know for a fact it's been that way since '93.
    Mods: FAST 90mm, Nick Williams 90mm TB, TR 230/224 .581/.567 111 LSA, CC 921 springs, Hooker LTs, Hooker ORY, SLP Loudmouth, Eibach Pro Kit, Billstein HD, Baer Eradispeed, Whisper Lid, BMR SFCs, BMR Adj. LCAs, BMR reloc. brackets, HPTuners. 418HP/390ft-lbs rearwheel on a DynoJet.
    NY
    2002 Camaro SS
    haha so if 5/8 is really 4/8, then when it says 1/8 i must be down to my last few drops of gas lol. good to know that particular problem isn't out of the ordinary. but what about the thing where i'll turn off my car, then the next time i turn it on the tank needle has moved down like a centimeter? assuming theres no leaks, shouldnt the amount of gas in the tank stay the same?
  1. CTSV gas tank problems
    By 4doortypels in forum Cadillac CTS-V
    Last Post: 10-21-2009, 06:01 PM
  2. Gauge Cluster Problems
    By JerseyLS1 in forum General Help
    Last Post: 04-15-2009, 06:43 PM
  3. Help: Fuel Gauge goes crazy around 1/4 tank???
    By 28Marcos in forum General Help
    Last Post: 02-02-2009, 03:28 PM
  4. Gas Tank/Gauge problem.
    By 95Fyrebyrd in forum General Help
    Last Post: 03-04-2008, 05:42 PM
  5. Gauge Problems
    By 99PFLZ28 in forum General Help
    Last Post: 03-03-2006, 07:53 PM
