Thread: Programing Keyless Entry
09-04-2005, 10:26 PM #1GOAT6SPDGuest
Does anyone know how to program a New Keyless Entry Remote Contol for my 02 WS6. I went by the dealer and they wanted 87 bucks. He told me it would take an hour. Thanks for the help.
09-05-2005, 09:02 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I wonder if it is the same on a F-Body?
09-05-2005, 11:19 AM #3GOAT6SPDGuest
I am sure it is.
09-05-2005, 11:27 AM #4Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Matching Transmitter(s) To Your Vehicle
Each remote keyless entry transmitter is coded to prevent another transmitter from unlocking your vehicle. If a transmitter is lost or stolen, a replacement can be purchased through your dealer. Remember to bring any remaining transmitters with you when you go to your dealer. When the dealer matches the replacement transmitter to your vehicle, any remaining transmitters must also be matched. Once your dealer has coded the new transmitter, the lost transmitter will not unlock your vehicle. Each vehicle can have only four transmitters matched to it. Have each transmitter you intend to match ready for the next steps. To match transmitters to your vehicle:
1. Turn the ignition key to RUN, then to OFF. This will disarm the Content Theft-Deterrent/Alarm System (if your vehicle has this option).
2. Remove the RADIO fuse. This fuse is located in the main fuse block which is located on the left side of your instrument panel. The radio fuse is located on the lower right-hand corner of your instrument panel. See “Fuses and Circuit Breakers” in the Index.
3. Turn the ignition key from OFF to RUN three times quickly (within five seconds). The vehicle will respond by locking the doors, unlocking the driver’s door and releasing the hatch. Your transmitter is now ready to match the vehicle. Leave the ignition in RUN.
4. Press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The vehicle will respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your transmitters, replace the RADIO fuse.
7. Check that all transmitters work by pressing their buttons.
09-05-2005, 11:27 AM #5Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I'm going to copy this to another forum
09-05-2005, 11:56 AM #6BlackHawk T/AGuest
Doesn't sound like that's worth 87 bucks, nor an hours time IMO.
09-07-2005, 04:24 PM #7
to dealers it does when customers are not savvy enough to read the owners manual hehe.
Help: Keyless Entry Went Out
By cammed goat in forum GTOReplies: 66Last Post: 10-12-2014, 10:07 AM -
keyless entry?
By bh5432 in forum Stereo and ElectronicsReplies: 4Last Post: 04-03-2008, 09:43 AM -
keyless entry
By emotionalpiracy in forum Computer & TuningReplies: 3Last Post: 01-13-2008, 09:32 PM -
Keyless Entry Fob?
By shlby123 in forum General HelpReplies: 5Last Post: 02-03-2007, 10:47 PM -
By GOAT6SPD in forum Western MembersReplies: 10Last Post: 09-07-2005, 03:48 PM
