    Etown, KY
    Previous 7.9 Can I make it?
    Well I have a bet with a friend for $100 dollars first of all. The bet is that I won't see a 7.2xx all season in the 1/8th mile. My best timeslip so far N/A was.
    RT .0802
    60ft 1.8581
    330ft 5.1982
    ET @594 7.4351
    1/8th ET 7.9302
    1/8thMPH 90.88
    Previously this was on Nitto Drag radials so there is much improvement ability for the 60ft area. I have recently bought some M/T ET Drag radials so that should help out alittle. Also I have tweaked the suspension some. Recently I have added a 125 wet shot of nitrous also... which I hope will bring my times down to that level. Thanks for the input!
    1999 Trans AM M6 394whp/375rwtq
    TR 236/230 Cam; Ported 98 Heads, Diamond Forged Pistons, Eagle Rods, Pacesetter LTs & ORY, Hooker Catback, SLP Underdrive Pulley, Ported TB, LS6 Intake, Moser 12 Bolt w/ 4.10s, KYB Shocks, BMR suspension, RAM HD Clutch w/billet flywheel....more
    Member 94 Formula's Avatar
    La Mesa
    M3 SMG 350HP
    [QUOTE=BoostedRS;320170]Well I have a bet with a friend for $100 dollars first of all. The bet is that I won't see a 7.2xx all season in the 1/8th mile. My best timeslip so far N/A was.
    RT .0802
    60ft 1.8581
    330ft 5.1982
    ET @594 7.4351
    1/8th ET 7.9302
    1/8thMPH 90.88
    You will run high 6's if you can hook with the power you will put down on the N2O. The new MT ET's will help you out very much. I have seen 1.4-1.6 60fts all day out of those tires.
    Dustin
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    where do you race at? wondering cause i race in northern KY and your not that far from me man
    Etown, KY
    I usually go to Beech Bend or Ohio Valley Raceway... you probably go to Clay City right?
    99 SS
    no i go to ThornHill(10 mins from my house) and EdgeWater, and also TRI-State in Ross Ohio, there all pretty good places to run, and really there not that far from you at all. i think im about 20 mins North of you
  1. Spaz's previous life
    By Knight in forum Almost Anything Goes
    Last Post: 05-28-2010, 02:56 PM
  2. Searching For Previous Owner
    By XKALIBER in forum Firebird / WS6
    Last Post: 02-22-2007, 03:08 PM
  3. previous ownership??
    By andrew69_04 in forum General Help
    Last Post: 12-27-2006, 08:42 AM
  4. Before you had an LS1 how much power did your previous car have?
    By 99blueZ in forum Almost Anything Goes
    Last Post: 10-04-2006, 01:45 PM
  5. My Previous Car And Current Car (16 Pictures)
    By compuvision02 in forum Member's Rides
    Last Post: 01-17-2006, 02:27 PM
