    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Novice Exhaust Question "Y" Pipe
    Yip I read the threads and will risk the butt chewing and ask a question. I have a Hooker CB Aerochamber on my 2000 Z28. The installer said I need a "Y" Pipe to free-up more flow. I see the term "Off Road" Y Pipes by SLP and others. Why are they called "Off Road" (something illegal for street)? I see the sales sites don't mention anything about emissions so assume this portion of the system is unaffected in that respect. I can easily see why a round pipe will flow better than a flat one. I would like to keep my sensors in place and stock headers for now. Thanks for the help.
    2000 Z28
    M6
    SLP Lid
    Smooth Bellows
    Hooker Aerchamber CB
    Junior Member Schweet97Z's Avatar
    Danville, PA.
    Mystic Teal
    1997 Camaro Z-28
    yes ory pipes are illegal. they dont contain cats. in my opinion there not worth the money when used with manifolds. save ur money for when u get headers..or do another mod.
    Navy
    2000 Z28 M6
    SLP Ad says "SLP's Y-pipe assembly is available for 2000-2002 Camaro/Firebird with V8 engines. Manufactured from 2-1/2" O.D., 409 SS tubing, it is mandrel bent for smooth, clean bends with superior flow characteristics. This Y-pipe assembly is designed to replace the "flat" factory pipe (behind the stock catalytic converters) and bolt to your stock exhaust manifolds." So am I to believe my cats are up stream and not affected? Maybe my first post wasn't very clear. They (SLP) further state up to 10 WHP gains possible. What do you think? Thanks
    Bragg NC
    Met. Sunset Orange
    01 SS
    Well it says it bolts too your manifolds so im guessin it eliminates your cats. Gonna have to call slp for more info. If your just tryin to replace the y and leave the cats then save your money. You wont feel any difference and if anything you will just create a headache from replacing factory y. Just my op. thou
    J
    Feb 2006
    Charlotte, NC
    2002 Z28
    No, the SLP Y was designed to go on after the stock cats and manifolds. The only difference between it and the stock Y is that the stock Y is flattened under the drivers side for clearance, but some flow tests (and not a few lengthy discussions on fluidic mechanics) about three years ago determined that you really don't gain anything with it. The GM engineers did a good job with the design of the pipe and it flows as good as you could want on stock manifolds and cats. All using the SLP pipe (or any other Y that is "legal") does is loose you an inch or two of ground clearance and a few hundred dollars.
    That being said, technically any other header/y-pipe combo besides shorties is federally illegal, since federal regulations state that it's illegal to move the catalytic converter any farther from the cylinder head than it was when it left the factory.
    However, if you're registered in NC, most of the places just do a curosory visual to see if you have cats. If one wants to be a dick and fail you for having long or mid-length headers and a catted Y, go to someone who doesn't. As long as the computer on OBD-II (post 1996) cars say your emissions are okay, you're good. Most will not, however, pass you if you go with an ORY (no cats at all).
    Navy
    2000 Z28 M6
    Great information and supports what I have been hearing. Thanks
    Burlington, NC
    Why don't you install a true dual exhausts system all the way out the back and forget that stupid "Y" pipe?
    JEB
  1. "Teen" Thugs Beat Man for Asking them to Pipe Down (vid)
    Last Post: 04-19-2015, 09:17 PM
  2. For Sale: SLP Stainless Steel "Y" pipe for '98/'99 LS1 F-Bod
    By Sam-SS in forum Parts For Sale / Trade
    Last Post: 03-01-2008, 06:01 AM
  3. Bassani Headers with cats and "X" pipe
    By Deneau Valteau in forum Parts For Sale / Trade
    Last Post: 07-02-2007, 05:48 AM
  4. SLP Stainless Steel "Y" pipe for '98/'99 LS1 F-Body
    Last Post: 04-25-2007, 10:52 PM
  5. SLP Stainless Steel "Y" pipe for '98/'99 LS1 F-Body
    Last Post: 02-05-2007, 12:14 AM
