Results 1 to 13 of 13
    Member JattGunMan's Avatar
    cali
    2000 ss
    Single Turbo Sugg.
    i was wonderin what you guys would recommend for a 01 camaro ss..sts is out of the ques since its not cali smog legal...so can u guys give me some kinda idea on what i should look at..i needa beat a 420 hp supercharged 96 cobra..
    boca, florida
    2002 Camaro SS
    procharger, d1sc with 8rib upgrade
    Junior Member Duke of Cruel's Avatar
    Jun 2006
    sweden
    red metallic
    1991 sierra cosworth
    Quote Originally Posted by JattGunMan
    Get yourself a hp performance turbo kit or a Pro turbo sysems kit.
    It will set you back about 6k for a single turbo kit,but then you will see 450-500 hp @wheels.
    boca, florida
    2002 Camaro SS
    if u got a turbo kit, 450 to 500 at the wheels would be the turbo on its lowest setting
    Jun 2006
    sweden
    red metallic
    Yeah black,
    it would be like 6 psi, because of the stock cr. lower it to 8.5 and you see an
    easy 600 at the wheels, still on pretty low boost.
    DoC
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I thought the STS was smog legal now??
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    cali
    2000 ss
    great responses guy and if you look hard enough on the sts site it says that its only for offroad use in cali
    Aug 1999
    No Where
    Hmm.. I found this on their site
    STS turbo systems are also one of the few turbo systems that have a CARB EO #, which means they've been tested and shown not to interfere with the emissions of a vehicle. Currently, the Camaro, 5.3L and 6.0L GM Trucks/SUVs and the Pontiac GTO are covered under EO# D-593.
    From CARB:
    EO: D-593 View PDF
    EO Date: 8/3/2005
    Manufacturer Name: Squires Turbo Systems, Inc.
    Device: Turbocharger Kit
    Device Type: Turbocharger System/ Turbocharger Modification
    Model_Specification:
    1999 through 2005 model year General Motors trucks equipped with V8 engines, 2004 and 2005 model year Pontiac GTO vehicles equipped with a V8 engine, and 1998 through 2002 model year Camaro/Firebird vehicles equipped with a V8 engine
    Modification_Allowed:
    The Turbocharger Kit includes the following main parts: Garrett turbocharger, model number T04E 60-1 (Trim P, 0.81 A/R turbine, 0.6 A/R compressor), piping from the throttle body to the turbocharger, piping after the muffler to the turbocharger, open element air filter, wastegate, and PCV switch valve. Control module is reprogrammed using a hand held programmer with no user adjustments. Installation requires the air filter to be located near the rear wheel fender. Passenger cars will have an open element filter and trucks may have either an open element filter or a closed element snorkel kit. Boost is limited to 6 pounds per square inch.
    cali
    2000 ss
    *At this moment all systems are for off-road use only in California, except for the Pontiac 5.7L GTO which has an EO# D-593.
    The STS(tm) Turbo System is installed after the catalytic converter, so for most states your vehicle will pass emissions. Check with your state emissions for specific regulations.
    if you go to there site and click products all the way at the bottom it says that
    Jun 2006
    sweden
    red metallic
    Ok then a little go fast is legal in cali.
    DoC
    Member dementia's Avatar
    Thornton Colorado
    2002 Trans Am
    If your looking to pass emissions I think your only options are STS for turbo or P1sc for superchargers.
    florida boca raton
    2002 ws6 trans am
    new procharger
    ati procharger on ebay good price D1
    florida boca raton
    2002 ws6 trans am
    new procharger
  1. Single turbo set up cost
    By Lunatikgixxer in forum Forced Induction
    Last Post: 05-24-2010, 06:26 PM
  2. Single turbo exhaust???
    By ARM5280 in forum GTO
    Last Post: 05-28-2009, 03:42 AM
  3. single turbo
    By chevyboy82188 in forum Forced Induction
    Last Post: 05-25-2009, 07:47 AM
  4. Z28 vs Evo 8 vs single turbo supra
    By drummer52910 in forum Kill Stories
    Last Post: 11-06-2007, 05:00 PM
  5. Ebay Single Turbo Kit
    By NiteRiderWs6 in forum Forced Induction
    Last Post: 06-03-2007, 01:11 PM
