    Jun 2006
    new york
    1996 trans am
    Low Oil Pressure At Idle
    1996 WS-6, 105,000 miles. Oil pressure starts out at 60psi, but after 20 -30 minutes drops at idle to between 10-0 psi. (check gages light comes on) While driving pressure is at 30-40psi ,only at idle is the problem.Engine sounds fine, no smoke or leak. Shop says oil pump replacement, roughly $450.
    Does this sound right to you guys?
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    bad bearing clearences (rod and crank) will give low oil pressure at idle also does it knock when the pressure is low? we switched an oil pump on a blazer w/4.3 with low oil pressure at idle (pretty big job and very expencive) and it still had low oil pressure when we were done. boy was that guy pissed but it wasnt my diagnosis so it didnt fall on me
    Jun 2006
    new york
    1996 trans am
    Dont here any knock at idle. If I keep idle at 1200-1500 she seems fine, about 30 psi. Is there a way to check bearings before going the oil pump route?
    Evr sena bdgr killa snak? Roastem's Avatar
    Research Triangle Park, NC
    '99 Z28 M6
    What weight oil are you using?
    Jun 2006
    new york
    1996 trans am
    10-40,10-50
    Junior Member Quicksilver Vert's Avatar
    Feb 2006
    CT
    Quicksilver
    2001 Corvette
    Bad Sensor?
    Check your oil pressure with a mechanical pressure gauge before you tear into the engine.It might be only a bad oil pressure sensor causing the problem.
    '99 Z28 M6
    Try the recommended weight with your next oil change.
  1. idle issues... idle high. unplugged tps runs good?
    By okiels1 in forum Firebird / WS6
    Last Post: 12-31-2016, 04:36 AM
  2. Help: Fuel Pressure 52psi at idle and gets 0131/0151 only at WOT
    By fst100 in forum General Help
    Last Post: 02-01-2012, 04:42 PM
  3. Help: intermittant rough idle, off idle hesitation
    By Matto4785 in forum General Help
    Last Post: 09-21-2009, 06:12 AM
  4. Idle Oil Pressure!!!
    By karpetcm in forum Internal Engine
    Last Post: 12-22-2008, 02:12 PM
  5. Replies: 20
    Last Post: 02-15-2007, 09:28 AM
