Results 1 to 10 of 10
    San Diego
    2001 WS6 Pontiac TransAm
    My key wouldnt start my Trans Am anymore!!!
    Cost me $400 to have the ignition cylinder replaced, and two keys. My question, has anyone ever had this problem before, is it common? Also, why couldnt I just get a new key? The guy at the dealership said you have to replace the cylinder as well.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    you can bypass VATS and not spend the $$$ if you just buy a resistor for 50 cents
    Member Bowtie Guy's Avatar
    North San Diego County,CA
    2002 Z28 M6
    If you look at your key,there is a resistor on it. When they get worn,they dont make contact inside the lock cylinder that sends a signal to the VATS. I dont know if there is a cheaper fix.
    VATS can be turned of with LS1edit.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by 0rion
    vats is in the bcm not the pcm, how does that work?
    nc
    2000 camaro ss
    What happpened is there is two little metal prongs (inside the ignition cylinder) that are very very small that read your key when your insert it into the cylinder. over time from repeatedly pushing in and taking out those prongs that read the chip on your key get worn down and sometimes broken and will not even read that your key is in the ignition. A new set of keys with resistor would not have fixed the problem. Tt is a somewhat common thing, it happened to mine!!
    I had the same problem.
    Mine wasn't the key but it was the rollers in the ignition.
    $300 or free resistor from a friend.
    Gee...let me think.
    Lowered, HID's, tinted.
    Quote Originally Posted by oneBADDz
    Lower right hand corner.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    sweet, I am a doubter no more. I'm glad you didn't take offence to my question and get defensive, seems that most would have. I never would have guessed you could do it that way. . .
    No problem. I've never set the vats off on my car but knew it was there. I'd like to hear if anyone has fixed this specific problem by turning it off with edit.
  1. Car Wouldnt Take Gas
    By CamaroFan71 in forum General Help
    Last Post: 08-04-2008, 06:03 PM
  2. wouldnt it be great
    By issues in forum Almost Anything Goes
    Last Post: 07-01-2007, 11:06 AM
  3. this wouldnt happen in a pro-gun administration
    By Modulistic in forum Political / Debate Forum
    Last Post: 03-30-2007, 05:37 PM
  4. Guy wouldnt install my gm motive gears?
    By therobman in forum Drivetrain
    Last Post: 01-04-2007, 06:11 PM
  5. Micheal moore wouldnt lie?....right?
    By Bigrus in forum Political / Debate Forum
    Last Post: 06-17-2006, 09:16 AM
