    live fast, die young.
    santa ana
    metallic blue
    1969 camaro
    Unhappy 69 camaro rims and tires size?!?! HELP!!!!
    ok so im trying to find the widest rim and tire pakage that can fit on a stock 69 camaro.... i curently have 215/70/r14 on the front and 235/60/r14 on the back... the off set is bad cause the front fires rub on the inner tire well when i uturn and the back tires get cut up by the rear bottoming out.... i need to know the propper off set and backspaing to fit good size tires, without having these problems..... if u know or have and idea... any at all it will help emmensly..... thanks
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    do you want 15", 16", 17", .....
    santa ana
    metallic blue
    1969 camaro
    i want 17s.... i figure if im gonna get new rims, i wanna go a decent size and make 'em look nice
    orlando, fl
    2014 camaro 2ss/rs
    do you want a split width front to rear? like 17x8 and 17x11??
    santa ana
    metallic blue
    1969 camaro
    Quote Originally Posted by mrr23
    yes i want to fit 235 on th erear and maybe 215s on the front... i just need to know the width rims i would need for that... and the proper offset and backspacing
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    a 17x8 will fit those tires fine. not sure on the backspacing. do you know the backspacing on your current rims?
  1. what size tires do I get for 20 inch rims on 01 TA
    By Kuddy Bing 85 01 TA in forum Wheels and Tires
    Last Post: 10-26-2014, 09:55 AM
  2. What size tires 4 rims??? HELP!
    By paugust73 in forum Wheels and Tires
    Last Post: 05-02-2008, 09:14 AM
  3. Replies: 17
    Last Post: 06-28-2006, 02:06 PM
  4. 69 camaro rims and tires size?!?! HELP!!!!
    By 69camarokid in forum Classic Muscle
    Last Post: 06-17-2006, 08:02 AM
  5. 69 camaro rims and tires size?!?! HELP!!!!
    By 69camarokid in forum Camaro / SS
    Last Post: 06-06-2006, 09:53 PM
