    Junior Member nabdrill's Avatar
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    I'm very frustrated
    Here's the deal...
    Out on the street my camaro shifts fine, 1-2 @ 6200, 2-3 @ 6000. I go to the track and the damn thing wont shift out of 2nd, drive out to the street and it shifts fine, Put it on the starting line where it hooks and it won't shift out of second. I'm hitting the rev limiter going thru the traps in the 1/8th. The rev limiter is set at 6500. IM BAFFLED, I DONT UNDERSTAND...
    I use the Hypertech 3 programmer. Shift points are set at -1 1-2 and -12 2-3. Tires @ 26" and 3:73 gears. All info is correct, i dont get it. Like I said, take it out on the street and just play around, everything does perfectly, pt it on the track and it wont shift. I'm just putting it in drive.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I know when I put my shifter in D instead of OD. My tranny shifts late.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    could be a few things, mine did this also before it was rebuilt.
    first the 2-3 clutch packs might be going out, of the solinoid(sp) is not holding pressure. i personally think its the 2-3 clutch pack that is wearing out in it
    Quote Originally Posted by Ed Blown Vert
    Have you ever heard/read why this happens? I've noticed that too. If I manually shift the car it shifts later than when it's in OD.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by Zboner
    there are no 2-3 clutch pack. it's a band to stop the drum for 2nd and 4th gears. you have a forward, reverse, and 3-4 clutch pack.
    detroit,mi.
    2002 z-28
    I have a problem that my car is hitting the rev limiter 1-2 and 2-3 ever scince i put in my gear. I have this problem all the time though i think i need to have the shift points adjusted.
  1. Getting really frustrated!!!!
    By ThunderChicken in forum Request and Feedback
    Last Post: 12-14-2010, 01:31 PM
  2. Help: Frustrated NEED Help
    By speedracer25f in forum General Help
    Last Post: 03-26-2008, 03:00 PM
  3. Help: Frustrated, need help
    Last Post: 03-17-2008, 07:46 PM
  4. frustrated
    By aPerfectTransAM in forum General Help
    Last Post: 09-04-2006, 07:12 PM
  5. Getting frustrated...Need Help!!!
    By Mr. Luos in forum Internal Engine
    Last Post: 03-03-2006, 09:14 PM
