Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Member 408WS6's Avatar
    Houston
    Current best: 10.60/126.8
    1998 Pontiac TA WS6
    Camshaft Degree Question
    Does anyone know if it is possible to check a camshaft to make sure that it had been degreed properly without removing the front cover off the engine?
    Is so, how?
    I do not believe so.
    Lowered, HID's, tinted.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    No, degreeing a cam involves having pretty much a bare block. At least to my knowledge.
    Australia
    93 VP Commodore ute
    Yes, it can be done easily with the manifold off.
    Quote Originally Posted by dyno355
    Depends on the motor.
    This won't work on the LS1.
    408WS6, are you wanting to check dot-to-dot???
    Australia
    93 VP Commodore ute
    Quote Originally Posted by Mr. Luos
    Even with a long stylus dial indicator down the pushrod hole???
    That will tell you roughly how the cam is timed. But not in relation to the crank.
    At least I believe that is how that works.
    Houston
    1998 Pontiac TA WS6
    well, that too. but all I need to do for that is pull the front cover off. I would like to stick a degree wheel on there and get more precise. Shops do cam installs without removing the heads, surely they use a degree wheel to check the cam??
    I had a motor built and I am seriously questioning whether the cam was degreed properly. Its a 408 w/ AFR 225 heads LS6 intake (I know, I need a FAST) etc etc. Car only put down 380 rwhp. The low end feels good but fades pretty quick getting closer to 6k rpms. Something is seriously wrong. That combo should put down 500 rwhp or close to it.
    I'm just wondering if the cam is too far advanced or a tooth off or something. It seems like I checked the dot-to-dot before I installed the motor and it looked ok.
    Oh well, it doesn't run that good but it sounds pretty good. Check it out:
    http://media.putfile.com/idle1-18
    http://media.putfile.com/idle2-24
    I'm determined to get to the bottom of this!!!
    Florida
    1999 TA WS.6
    yea, that doesnt sound right.
    Houston
    1998 Pontiac TA WS6
    Quote Originally Posted by Hi-Po
    Are you referring to the idle?
    Australia
    93 VP Commodore ute
    Thats why you use a positive stop down the spark plug hole to set your degree wheel. If your not checking camsahft instalation in relation to the crankshaft then your wasting your time.
    408WS6
    I've degreed cams before that have been gound out of phase up to 7 deg. This means that fitting a cam dot-dot is pot luck. This is more commen with the larger well known cam grinders unfortunately.
    Florida
    1999 TA WS.6
    Florida
    1999 TA WS.6
    Quote Originally Posted by 408WS6
    Houston
    1998 Pontiac TA WS6
    This is exactly what I am afraid of. Guess its time to go get greasy...
    thanks for the help guys
    Just listened to it.
    What is your valvetrain set-up???
    What pushrods..length included?
    What lifters?
    What cam?
    What springs?
    And since I am here....can you get footage of it idling with the hood up??
    Houston
    1998 Pontiac TA WS6
    What pushrods..length included? 7.400" comp rods, stock rocker arms
    What lifters? Crane hyd rollers
    What cam? Cammotion 244/249 .630" lift 114+4 LSA
    What springs? Comp dual springs w/ titanium retainers
    The heads were milled .030" so I shimmed the rocker arms so that they had about 1/3 to 1/2 turn preload on the lifters, so I'm pretty sure thats ok.
    Give me a minute and I'll get a video......
    Houston
    1998 Pontiac TA WS6
    Here is a vid of the engine running w/ the hood up:
    http://media.putfile.com/idle3-82
    Houston
    1998 Pontiac TA WS6
    There IS alittle more to the story. Im using a TH400 w/ reverse valve manual body and transbrake (the transbrake is alot of fun ) and a loose 3600 stall converter (no lock-up). I've been told that combo right there zap alot of power, but I didn't think it would be 100 hp!!
    Also, I bought used SVO 42# injectors (I know, bad idea) so I'm thinking about havin them flow tested, or just ditch em and get some new ones. I'm wondering if this isn't the source of my lost power.
    Any ideas on why this motor is missing at least 100 hp let me know, I would greatly appreciate it!!
    Something doesn't seem to sound right, but I can't put my finger on it.
    Is it running REAL rich?? Backfiring at all??
    What length pushrods?
  1. Camshaft Question
    By Ramairgod84 in forum Internal Engine
    Last Post: 05-06-2009, 10:05 AM
  2. Flow Tech camshaft question
    By 98ls1blackbird in forum Internal Engine
    Last Post: 10-27-2007, 08:59 AM
  3. camshaft question, need help
    By laststaric in forum Internal Engine
    Last Post: 12-16-2006, 10:04 PM
  4. Hot Rod article (camshaft question)
    By Eric_The_Jew in forum Internal Engine
    Last Post: 10-17-2006, 05:34 PM
