Results 1 to 10 of 10
Thread: code P0300
06-01-2006, 05:35 AM #1Junior Member
- Dec 2005
- florida
red- 1999 corvette
code P0300
'99 corvette engine falls flat on it's face for a short period of time then clears itself and seems to run pretty much ok.While this is going on the exhaust smells horrible.
Acceleration does not seem as strong as other vettes I have sampled.It seems to come alive but with a little delay.I was cruising at steady 60mph yesterday when it happened, this time it coded p0300 which was multiple random cylinder misfires.It lasted for a couple of miles. This happened when I first bought the car in Nov. and only three times since then but never showing a code.The check engine light flashed a little while before going steady and then the car was running smooth again.
The engine was changed in Jan. so it has happened with both engines.
The only reused parts from the old engine were the intake and the fuel injectors.All else was brand new GM out of the box.Plug it in and run.
I hope some one can help me because this car is about to break the 10k repair bills since nov.
06-01-2006, 11:36 AM #2
Man, I posted this same thing up on here about a week ago because my TA does the same thing pretty much but no one really replied to it.
Hope you have better luck with it.
06-01-2006, 11:54 AM #3Senior Member
- Jul 2005
- Jacksonville, FL
My car has thrown P0300 a couple times over the years, but just cleared the code and hasn't come back for several months now since the last time. Both you guys need to look it up at www.gearchatter.com maybe you can find an answer there.
A4(3.42)TA Cover/Nittos/Vig 3200/Corsa Catback/FTRA/BMR Boxed SFC, STB, ACLA, APHR/Predator Custom Tune...
06-01-2006, 03:20 PM #4Slow'er'Ass
- Thornton, CO
I can't NOT throw that code.
It is a random misfire.
Plugs
Wires
O2's
Fuel2008 Trailblazer SS
Lowered, HID's, tinted.
06-01-2006, 07:49 PM #5Junior Member
- Dec 2005
- florida
red- 1999 corvette
Try this???
I have a friend who is a service writer now that he is almost disabled from working on these ground hugging machines. He said it is most likely a fuel delivery problem and that a fuel pressure guage and hose assy should be attached to the fuel rail and taped to the winshield to observe the fuel pressure when the malfunction manifests itself. Record the reading and see if it falls within spec.The fuel pressure with the key turned on to cycle the pump then turned off should be 50-62 lbs. He feels it is a fuel pump getting ready to leave me stranded. The info at gear chatter is helpful if you have a GM scanner toanalyze the info,but it is informative.I am taking the car to the dealer Friday and leaving it until they fix it. I am so over this car. if it was the only thing I owned and it disappeared I wouldn't even go look for it.
Good luck
06-02-2006, 03:52 PM #6Slow'er'Ass
- Thornton, CO
WOT you want at least 52-53 PSI.
06-02-2006, 05:11 PM #7Junior Member
- Mar 2006
- Springfield, OH
Bright Rally Red- 2001 SS Camaro
P0300 Code is Mutiple Misfires detected
Try Changing Your Fuel Pressure Regulator Sounds Like The Diafram Is Sticking
If You Guys Have Any Other ? Feel free to Email Me [email protected]Last edited by Scott Stookey; 06-02-2006 at 05:16 PM.
06-02-2006, 07:30 PM #8
My TA did the same thing and then run fine for a little while so i hooked the GM scan tool up to it at work and one of the O2 sensors was showing high voltage. That solved my problem by replacing it
99 Trans Am M6
SLP lid/FRA/TBB/Comp 224/224 581/581 112LSA
Comp 918s/Comp PRs/Hedman TorkStep LTs
Custom Y/Exhaust/Pro 5.0
06-04-2006, 06:48 AM #9Junior Member
- Dec 2005
- florida
red- 1999 corvette
new code P0420
Last night I took a leisurely ride for about 50 mi. no problem . Jumped on the throttle got up to 70 mph and cruised it for a few more miles.Got off the main road and on comes the check engine light. Car feels like it has a slight miss so I scanned it again and here it is P0300 and P0420 bank one catalyst below threshold.
Now what???
It seems I am chasing a moving target with my ATM card.
06-04-2006, 06:58 AM #10Slow'er'Ass
- Thornton, CO
Could be a clogged cat. Check that first.
P0300 misfire code...help:(
By Lotapwr in forum General HelpReplies: 7Last Post: 05-02-2013, 07:19 PM -
P0300 code random misfire...
By MagicMan in forum General HelpReplies: 87Last Post: 07-31-2009, 01:27 PM -
Damn P0300 code again
By Hurley711 in forum General HelpReplies: 24Last Post: 05-14-2009, 04:17 AM -
Question: P0300 Code on 2002 Trans Am WS-6
By axvick in forum Firebird / WS6Replies: 3Last Post: 11-23-2008, 03:19 PM -
P0300 Code - HELP
By oldguy in forum GM TrucksReplies: 1Last Post: 09-05-2007, 05:33 PM
