Results 1 to 19 of 19
    CT
    2000 camaro ss+ 1987 GN
    1969 Z-28 vrs 2002 Mustang
    I was checking out the Mustang siteont ask: and anyone here thinks a 2002 Mustang GT would beat a 1969 Z-28 with 456 gears? I had a Z with 456s and it would not even be close. I like most fast cars but some of those Mustang guys dont have a clue.
    live fast, die young.
    santa ana
    metallic blue
    1969 camaro
    ha
    dude the z28 woulda smoked him.... 2002 gt have roughly 260 hp and 300 lbs of torque, vs a 69 camaro z28s roughly 400 hp and torque stock, plus they both weigh relatively the same.... theres no way he could keep up, even if u had shitty gearing
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    69 z 28 with a stock 302 cubic inch was rated 290 at the crank so what fantsy book are you reading and btw i think it ran the quarter in low 14 seconds about the same as the gt and with 456's your top end would be about 110 tops so he would take you on the highway
    CT
    Quote Originally Posted by twozs
    Sorry your wrong. The 302s were closer to 380 at the crank. With stock 373s they ran low 14s but with 456s they ran much faster. Check out this link.http://www.holisticpage.com/camaro/camaros/302.htm
    VA
    Hugger orange
    69 Z/28
    Having owned multiple newer Mustangs... 92 5.0, 97 Cobra and 03 Cobra and multiple 69 Z's in various stages of modification here's my .02 cents. The "stock" 69 Z is a stone. It got it's butt whooped on a regular basis back in the 60's. Now if you added headers, gears, through the crappy carb in the trash and put a properly jetted Holley 4779 750 carb on, it ran pretty repectfully (mine would run 12.80's all day long). Against a "stock" new Mustang the moded Camaro could probably take the win light as long as you did not goon a shift or bog it out of the hole. NOW, if you make those same tuning mods on the Mustang....headers, gears and induction.......don't bet your pink slip! The 1969 Z/28 is an icon of the 60's and one of my favorite cars of all time, but like many other stories and fables these cars have enjoyed some pretty tall tales about them.
    Technology is undeniably the advantage here. If you would look at dyno sheets of both cars you would clearly see the Mustang makes more power across a much larger RPM band. That means the Camaro only has a possible advantage for a very short time, but is behind the curve most of the time. The new cars are like DC motors, they pull through the entire RPM band and under all throttle settings. The dyno runs only show one throttle position "wide open" Hands down the better power maker and power potential resides in the Mustang FI engine. Try and match the power of the new LS series engines with the durability, performance and economy. Friends......love the car for what it is, a true classic muscle car and let the fables be told. Just don't get caught at a stop light with your stock Z against one of the new power houses.
    CT
    Quote Originally Posted by 1coolC2
    You made some good points but a stock Camaro Could be had with 456s+headers and would beat an 02 mustang that does not have those options. Thats the car im comparing it to.
    VA
    Hugger orange
    69 Z/28
    Quote Originally Posted by rug
    I'll buy the 4.56's coming on the 69 as an RPO....but NOOOO Camaro was EVER delivered with headers on it, or in the trunk (anouther fable). Factory headers were an over the counter service part like the crossram.
    The 450HP quoted in the article above was a heavily modified 302 by Traco. The cylinder heads, camshaft and carbs were extensively modified for SCCA racing. The cam used was only good for high RPM endurance use needed for road racing. Something to also keep in mind is how HP was rated then and now. Compare a 350 HP 350 CID engine from the 60's to a LS1 350HP, no comparision LS1 gets the checkered flag. Don't get me wrong, the 302 CAN make power if it's properly equipped. Put a set of Phase 2 Bowtie heads and a #140 off road cam and that bad boy will talk to you. Just so's happen I did one like that with 4.10 gears and it ran great. Just had to drive it like you wanted to break it Bottom line, equally modified.... the the newer engine will infact out perform the old one. Now ask me which one I like better.....The Z of course!
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    380 hp and only capable of 14 second passes, please! 380 might have been with the cross ram but wait, you read it on an internet link ,IT MUST BE TRUE!why would gm waste all that money on 290 hp stickers
    CT
    Your Right, i posted the wrong link. I had a 1969 in 1074 and they did dyno them with nothing on the motor. my best guess having owned one and from others back then is around 290 to 310, at the wheels less of course but still enough to beat a 2003 Mustang, JMO
    San Jose
    Green
    1969 Pontiac Firebird 350
    I think a 1969 Z-28 302 would smoke a 2002 mustang gt. If the mustang had a few mods on it like headers, you might not win.
    badass67
    Guest
    The 69 Z-28 came with a few different engines.
    The DZ-302 was the one that ahd the torque and power, it probably would beat a stock 02 Stang, with the 456 in the 69.
    However, the 350 in the 69 was weak.
    Also, most of the 1st gens had power then that is not near the power we get today.
    My 67 had a 327 in it, 210HP at the crank!!!!
    Yes, the 1st gens look damn fine and where fast in those days, but unless they are mod'd, they cannot keep up today. No biggie, the style and rareness of them makes they so good now.
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    Quote Originally Posted by badass67
    The 69 Z-28 came with a few different engines..
    WTF! PLEASE ELABORATE ON THAT STATEMENT! shhhhh.... this i got to hear!
    southern Indiana
    The only engine available on the 69 z-28 was the 302 with either one or two holleys. A 350 camaro was not a z-28 in 69. That happened in 70.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    A 2002 Mustang GT will do 0-60 in 5.7 seconds and cover the 1/4 mile in about 14 flat. Whether a 69 Z28 can match those numbers or not, I don't know.
    The 4.56 gears really turn the tables as well, so who would win is anyones guess.
    Now Know As Camaro98
    Aug 2006
    Payson, Utah
    1998 Z28 Camaro
    the Z would win, hell ive race mustang GTs in a truck with 315 at the crank and beat them on the street 0-75ish they strat pulling me aftter that speed but like i say the Z would win and as for bashing the old motors you dont know what your talking about 396s for the most part had 350-375 at the crank and dont get me started on the 427, my dad had a nova with a 396 with the only mod being a carb, and and intake he ran 13.2s all day long
    Future Super Trooper Mr. CarelessAndImprudent's Avatar
    Rolla, MO
    '69 Camaro
    Back in the day, the problem was traction, not power production.
    Impounded x-40oz-x's Avatar
    1981 g-Body
    Quote Originally Posted by 1coolC2 View Post
    I agree with EVERYTHING you've said so far.
    As much as i hate to say it, it's true.
    As great as the 69 Camaro was-stock for stock the 02 GT would win.
    The 4.56's will make a difference though.
    CT
    Quote Originally Posted by Wesman View Post
    The thing i cant figure out is why the 2002 ran 14.0 when every other link for 03s 04s say they ran 14.7s. Was the 02 that much different? Also i wonder if theres a way to figure horsepower by weight, 3500#+ 373 gears+ 140 mph top speed, no overdrive
    Arizona
    Green&Teal
    1993TA 1998Z28
    Cool
    Gotta agree, the Stangs ran high to mid 14's same as the Camaro with the stock 3.73's. With the 4.56's the 69 would pull it.
  1. 1969 Pontiac GTO Judge & 1969 Ford Mustang
    Last Post: 06-15-2015, 09:40 AM
  2. 1969 Ford Mustang - Anvil
    Last Post: 05-05-2011, 02:20 PM
  3. 1969 Mach 1 Mustang!!!
    By bluefields88 in forum Almost Anything Goes
    Last Post: 08-31-2009, 08:40 AM
  4. 1969 Ford Mustang - Tasca Super Boss
    Last Post: 06-29-2009, 10:50 PM
  5. 1969 Ford Mustang - Blackened
    Last Post: 10-01-2007, 12:15 PM
