Results 1 to 1 of 1
Thread: How NOT To Fish
05-23-2006, 09:33 AM #1
How NOT To Fish
Those of you that like to go fishing and aren't new to it should appreciate the humor in this:
1-Rev up your engine when you approach a fishing spot. Let the fish know you're coming and they'll swim out of the way.
2-When fishing shallow water wear a white shirt and cap so the fish can see you.
3-Rattle your tackle box and stomp your feet on the bottom of the boat. Sound travels well through water and fish have an excellent sense of hearing.
4-Don't match the tackle to the species you are fishing for.
5-Always fish with your back to the sun, especially early and late in the day. The longer your shadow the more fish you can spook.
6-When fishing a stream, make sure you find a nice high bank and move around a lot. The fish will see you against the sky.
7-If you should accidentally hook a fish, drop your rod tip and let your line go slack. The fish should be able to spit the hook.
8-Never change lures. If they aren't biting what you are throwing, stick to it. If you change you may get bit.
9-Cast directly to a fish. If you cast past it and retrieve it by the fish, it may grab your bait.
10-When fishing live bait, make sure you use the heaviest terminal tackle possible. That way your bait will look un-natural and reduce your chances of getting bit.
11-Make sure you wind up and launch the anchor as high as you can so you can make a big splashdown and let them know you are there.
new boat, Where's the fish?
By Jays00ss in forum Rocky Mountain MembersReplies: 18Last Post: 08-03-2007, 11:27 AM -
all my fish died of ick so i cleaned everything and moved my fish tank
By Ice Spiral in forum Almost Anything GoesReplies: 33Last Post: 05-29-2006, 04:22 PM -
So long! And thanks for all the fish.
By nitrox28 in forum Almost Anything GoesReplies: 7Last Post: 04-07-2006, 02:45 PM
