    Junior Member LangeZ28's Avatar
    Windom, MN
    2001 Camaro SS Convertibl
    B&M Tranny Cooler
    Which B&M Transmission Cooler is the best for F-Bodies? One with a fan or not? Which P/N? Where is the best place to mount? No zip tie nounts!
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Most everyone uses the 70264. It is a complete universal install kit with hoses and push thru-radiator retainers. You don't need the one with a fan option, but you can. Be advised those and the race coolers do not have any mounting hardware or universal install kits. You will need 1/2 NPT adapter to your preferred lines. Hope this helps ... I know, a bit late.
    George P. Lara
    Mine 2001 Camaro SS #0391: FQuick Garage
    Mrs.'s 2002 Camaro SS #7072: FQuick Garage
    Senior Member
    Jacksonville, FL
    I installed the B&M 24K, mounted it dope style (horizontally under the right front, no zip ties) no problems.
    Windom, MN
    Thanks for the feedback. I will probably go with the one that can handle 24K.
    Jun 2006
    GA
    Maroon
    86 Trans Am
    its not what one its where you put it 100% if you put it in front of the rad. and like 50% if you put it behinde the rad.
    you're gay mighty username's Avatar
    Chicago, IL
    RED
    I have the B&M mounted in front of the radiator on the lower right corner. i also have a tci deep pan. That along with some moderation in driving is enough for my setup.
  1. B4C comes with tranny cooler is that enough
    By Z28boy2000 in forum Automatic Transmission
    Last Post: 11-03-2009, 05:03 PM
  2. Question: Best tranny cooler to buy?
    By clg82 in forum Automatic Transmission
    Last Post: 04-05-2009, 03:38 PM
  3. tranny overheating, need bigger tranny cooler?
    By djvaly in forum Drivetrain
    Last Post: 03-22-2007, 03:25 PM
  4. tranny cooler for m6?
    By third_shift|studios in forum Manual Transmission
    Last Post: 10-11-2006, 09:00 AM
  5. Tranny Cooler
    By easyericvan in forum Drivetrain
    Last Post: 01-02-2006, 06:06 PM
