Thread: BBc Heads and Valves Questions
05-17-2006, 05:24 PM #1Junior Member
- May 2006
- Minnesota
Blue- 1984 K20
Hello, I have a 454 30 over that I am putting together. I will be putting it in a 84 k20 truck with one ton axles. I have 148 heads that need rebuilding. My first question is shopuld I stick with the stock size vaves or go bigger with a set of 2.19 intake and 1.88 exhaust? I also have a choice of cams , a comp cam 520 lift 290 advertised duration, or edelbrock 500 lift with 292 advertised duration. I will be putting on a Edelbrock airgap intake with aEdelbrock750 Carb. I have been told many things of what do to I would be interested in hearind what you people have to say. Thank You!!
05-17-2006, 06:45 PM #2What exactly are you're goals with the Big Block though? Are you looking to run a certain number at the track, on the dyno, or are you simply building yourself a boulevard bruiser?
Originally Posted by campajs
05-18-2006, 05:42 AM #3Junior Member
- May 2006
- Minnesota
Blue- 1984 K20
BBC Heads
Thanks for the reply. I have a big truck and will use it for pulling and working. I will also use it on the street quite often. Looking for high performance but not something a person can,t drive on the street.
05-18-2006, 02:27 PM #4
don't need larger valves. i would say to go with the comp cam just by the specs you listed. really need to know the rest of the specs of each cam to give a better opinion.
WTB a good and not warped set of valves for 853 ls1 heads
By ssdungeon in forum Parts Wanted / TradeReplies: 0Last Post: 08-22-2011, 10:42 AM -
241 heads with valves and springs $150
By Dr.Crash in forum Parts For Sale / TradeReplies: 0Last Post: 01-25-2009, 10:19 PM -
Help: Ls2 heads....what kind of cam & valves!
By cz28mdn in forum Internal EngineReplies: 2Last Post: 10-14-2008, 08:00 PM -
Ti valves for RHS 210 Heads
By Leatherman in forum Internal EngineReplies: 0Last Post: 04-22-2008, 04:47 AM -
F/s 317 heads ported and 2.02 1.60 valves
By we_todd_did in forum Parts For Sale / TradeReplies: 11Last Post: 12-12-2006, 12:37 AM
