Results 1 to 11 of 11
05-17-2006, 05:45 AM #1
Will suspension/chassis mods help?
I'm a newb to this stuff, but if all these things such as LCA's, SFC, panhard rods, torque arm, etc make more power to the ground, will I feel a difference in the power of the car since it should be making more RWHP? Will f body's dyno higher with only mods like these?
1999 Trans Am M6
SLP Short Throw, Lid and CAI, Strano Springs, Koni Sport Shocks, BMR STB and SFC, UMI PHB, Pacesetter LT's and ORY, Magnaflow Catback, DMH 3" E-Cutout, LS7 Clutch, Motive 4.10, 160 T-Stat, MSD wires,, 17x9.5 Chrome C6's wrapped in Hankook 275/40/17
Tuned at Mongillo Motors in New Haven, CT - 303 RWHP and 308 RWTQ
05-17-2006, 02:21 PM #2
suspension mods won't affect rwhp of the motor. all you are doing is getting to use the most of what you have. you can launch harder before tire spin comes into play. this, in turn, lowers your 60ft which lowers your ET.
05-18-2006, 02:48 AM #3
Gotcha. Thanks for the explanation.
05-27-2006, 12:39 PM #4JohnnyGTOGuest
You will not pickup power. You allow the car to have more USABLE power. This is why most built Supras run 12's no matter how much power they make. Without the correct suspension and chassis setup you can still run horse shit times.
Right now I am finishing my suspension as that is what's limiting my car. Not only does your car have better traction, but you have way better handling, and reduce chassis flex.
05-27-2006, 05:12 PM #5
A well balanced suspension setup will make your car safer and alot more fun to drive. Regardless of power.
'99 SS 'Vert M6 - Lid, TB, LS6 Int., Mac LT's w/ORY, Corsa Exh., Textralia Hybrid w/Billet Fly., Edelbrock IAS F/R, LCA's, STB, Tq. Arm, Baer GT+ Kit, 17x9.5 & 17x11's, Wolfe 6-Pt. Cage.
www.keithcraftmotorsports.com
[email protected]
05-29-2006, 09:38 AM #6Junior Member
- Dec 2005
- Buffalo, NY
Black- 1999 Trans Am WS6
Originally Posted by 99SS'Vert
05-29-2006, 09:51 AM #7Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
First line of mods I did was suspension. Did SFC, LCA and PHR all at the same time, and damn did the car ride much tighter than when it was stock. Best suspension mod I did however was Bilstein HD shocks. Completely changed the way the car drove and handled. As stated above all the power in the world doesn't mean shit if you ar not putting it to the ground.
05-30-2006, 11:51 AM #8
where are you from in CT
05-30-2006, 06:37 PM #9
I'm about twenty minutes north of hartford... if you drive the speed limit
05-31-2006, 07:55 AM #10
i'm in manchester, where u from
05-31-2006, 12:06 PM #11
Suffield, if you've ever heard of it.
$2000 on suspension mods or on motor mods??
By greatwhiteZ28 in forum Suspension and HandlingReplies: 6Last Post: 09-27-2007, 06:04 AM -
Beefing up chassis and/or suspension...
By AKIRA in forum Suspension and HandlingReplies: 7Last Post: 11-04-2006, 04:56 PM -
Chassis, Suspension Parts and Brands
By mrr23 in forum Suspension and HandlingReplies: 2Last Post: 01-02-2006, 07:07 AM -
WTB:Quality used Chassis/Suspension Parts
By Gregg1LE in forum Parts Wanted / TradeReplies: 2Last Post: 08-11-2005, 07:50 PM
