    Member aquickfive0's Avatar
    cocoa beach florida
    pewtr
    2002 Trans am WS-6
    need help with tires for strip
    i have a 2002 trans am ws-6 with a sts turbo
    i just ordered for the rear some centerline 15 x 10 with 3 1/2 backspacing
    i have 275-40-17 now
    these should fit right?
    now what size tires should i put on them for the track
    im wanting to get mickey thompsons
    this is for the track on and il put mine back on for street
    2002 trans am ws-6 auto.
    pewter
    sts turbo system
    12.6 @114 @4psi
    Junior Member nabdrill's Avatar
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    The 15x10 w/ 3.5 backspacing are gonna stick WAYYYYYYYYYYY out the side.
    They will fit though, but expect about 4" of tire looking out. I just put the 15x8's with 5" backspacing on my car and they stick out about an inch past the fender, i have pics posted on this forum
    cocoa beach florida
    pewtr
    2002 Trans am WS-6
    so what size would you put on these so it dont rub fender?
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    to acheive 0 rub you will have to figure what will has 2" or less front spacing. Just take the rim width minus the backspacing.
    THe weld prostars have the right size, but it takes alot of mods to get them on the car. I like the centerline convo pro's 15x8 with 5" backspacing. I have the hoosier quil-time DOT tires.
    Are you putting a complete set of 15" wheels around the car, or are you just getting a set of rears for the strip?? If your just getting a set for the strip then find you some stock camaro/firebird 16" wheels and get some tires for those, then you know the spacing will be perfect.... just my thoughts.
    cocoa beach florida
    pewtr
    2002 Trans am WS-6
    im just doing the rears and only gona be on for the track, i got a set of centerline 15 x 10 with 3 1/2 backspacing, what size tires would you put on them so it dont rub the top of my fenderwall
    i want mickey thompsons
    Rods99Z
    Guest
    If your going with a 15x10 wheel you need to have 7.5 backspacing. I have run this size wheel with 275x50x15 Mickey Thompson Drag Radials with no problems. Hope this helps.
    juiced00ss
    Guest
    Iam ordering the weld prostars with a 15x10/7.5 b.s for the rears with a 15x3.5 1 3/4 backspacing for the front. Tires for the rear are also 275/50/15 M/T E/T street radials.
    Question how much am I going to have to grind the calipers to make these fit?
  1. Hockey strip/Dick Harrell strip
    By ReSSurected in forum Appearance Section
    Last Post: 10-03-2008, 05:13 PM
  2. The strip.
    By xtinked in forum Mid-West Members
    Last Post: 01-06-2008, 05:55 PM
  3. The Strip
    By 2000T/A Guru in forum Kill Stories
    Last Post: 04-29-2007, 08:28 AM
  4. To strip of not to strip
    By sills1 in forum Wheels and Tires
    Last Post: 08-08-2006, 06:30 AM
  5. What tires are you running on the strip?
    By jimbo98z in forum Drag Racing
    Last Post: 11-29-2005, 07:55 AM
