Results 1 to 2 of 2
    Dumfries VA
    99 Camaro SS
    Driver side window problems... not motor
    99 Camaro SS
    I have a problem with my driver side window as a direct result of my car alarm went off. Initially the door lock did not work for the driver side although the driver side switch worked. then i turned on the car and the door locks worked for both sides. As for the window it is not the motor for i replaced it already about a month ago. The switch's continuity works. I hear a relay clicking under the dash... any suggestions? Thanks
    If either door lock switch is unplugged, power door locks will not work. I think it is the same with the window motors. The switches complete the circuits... try asking a friend if you car borrow their door lock/window swiths panels from both of their doors. They just pop out, you don't need tools. Put these into you car and hope.
    good luck,
    Dustin
  1. Wanted: Fbody Driver Side Power Window Motor
    By Zaccagnini in forum Parts Wanted / Trade
    Last Post: 10-23-2008, 12:23 AM
  2. Help: Driver side window motor dying????
    By Poppn in forum General Help
    Last Post: 07-20-2008, 09:10 AM
  3. WTB: MAF for LT1 and Driver's side Window Motor
    By efirdj in forum Parts Wanted / Trade
    Last Post: 01-02-2007, 04:21 AM
  4. Driver side window motor
    By ram air ws6 in forum General Help
    Last Post: 09-03-2006, 10:35 AM
  5. driver side window problems... not motor
    By Staggart in forum General Help
    Last Post: 05-16-2006, 08:36 PM
