    Super Sporting It Chevypowr's Avatar
    Allentown, PA
    1999 Camaro SS
    Exclamation NEED TORQUE SPECS, help please
    Does anyone have the bolt torque spec for the rear lower control arm for a 1999 f-body, I replaced my stock bushings with energy poly's and I tightened the hell o ut of them but I just want to make sure they are at the proper spec. Any info or links would be great.
    Borla XR-1 energy bushings UMI B&M Spohn suspension techniques eibach edelbroc K&N Richmond Eaton F.A.S.T FlashTuner NGK MSD SLP J&M - I owe it all to my mentor- my dad.
    Santee, CA
    According to the Haynes 1993-2002 Camaro/Firebird Repair Manual:
    1993-2001 = 80ft/lbs
    2002 = 87ft/lbs
    If you overtighten these, you will experience a noise problem.
    Also, the bolts should be torqued while the suspension is loaded.
    Vance Chula
    1996 Camaro Z28 SS #1688
    2010 Camaro 2LT RS
    http://www.cardomain.com/id/vchula
    Allentown, PA
    1999 Camaro SS
    Thumbs up !
    Quote Originally Posted by VChula
    2002 = 87ft/lbs
    Good Man! Thank you. I really need to pick up a manual of sorts.
    Santee, CA
    Quote Originally Posted by Chevypowr
    You're welcome!
    You can get the Haynes Manual (#24017) at AutoZone or Pep Boys.
    They only cost $10-$15.
  1. Torque Specs?
    By irishpenguin13 in forum General Help
    Last Post: 05-14-2009, 04:48 PM
  2. Torque specs
    By JMac in forum Internal Engine
    Last Post: 02-22-2009, 06:43 AM
  3. torque specs
    By 0rion in forum General Help
    Last Post: 03-12-2007, 04:58 AM
  4. Torque specs please
    By Chevypowr in forum Drivetrain
    Last Post: 05-09-2006, 04:48 AM
  5. I just need torque specs
    By mikriman1 in forum Wheels and Tires
    Last Post: 04-23-2006, 04:42 PM
