Results 1 to 2 of 2
    Junior Member SoAlWS6's Avatar
    Feb 2025
    Mobile Alabama
    Black Metallic
    2002 Pontiac Trans Am WS6
    Fuel pressure test
    I am trying to test my fuel pressure on my 2002 Trans Am with ls1. I checked it at the Schrader valve and got 54 PSI but when the pump shuts off it drops to zero. I am trying to isolate the injectors to see if the check valve is bad in the fuel pump and not a leaking injector. If I disconnect the quick connect at the fuel line coming into the fuel rail I could hook my fuel pressure gauge there and check the pressure bypassing the injectors. That would verify if I have a bad check valve. I need a 3/8" quick connect adapter that I could use to do this with. My fuel pressure test gauge has the Schrader valve fitting on it, I don't know the thread size.
    What is the thread size on the fuel rail Schrader valve fitting?
    I found a 6an male flare to 3/8" quick connect, it does not fit my gauge fitting.
    Feb 2025
    Mobile Alabama
    Black Metallic
    Got a 4an male to to 6an female adapter, will allow my 6an to 3/8" male quick connect at the fuel rail supply.
  1. Fuel Pressure Test - Assistance Requested
    By pajeff02 in forum General Help
    Last Post: 05-14-2014, 02:24 AM
  2. Help: Fuel pressure test failure, where to start?
    By LS1 oldtimer in forum External Engine
    Last Post: 03-26-2013, 05:38 PM
  3. How do you test a fuel pressure regulator?
    By cullywoo in forum General Help
    Last Post: 09-09-2012, 12:09 PM
  4. Replies: 3
    Last Post: 04-01-2006, 03:59 PM
  5. Looking for gauges! nitrous pressure, fuel pressure!
    By texasss in forum Parts Wanted / Trade
    Last Post: 10-29-2005, 09:05 AM
