Results 1 to 1 of 1
Thread: hydraulic clutch issues
09-28-2024, 03:00 PM #1
- Sep 2024
- Iowa
green- 1968
I have a LQ4(long crank) mated to an SM465. I am using a Speedway 3/4 clutch master cylinder and a speedway hydraulic throwout bearing, these are supposed to work as a kit and are supposed to work with an SM465. I have everything hooked up and bled, the pedal feels good and the cluth is working but it is not disengaging all the way. I can see that the friction surface is off of the flywheel but it is still in contact with the pressure plate so I think i need get more travel out of my TOB. I have spent several weekends bleeding and adjusting but I cannot enough travel and after a lot of research I am pretty sure I have everything set right.
I am trying to find a 7/8 clutch master with 1 3/8"(ish) stroke but I am not having much luck. Any suggestions?
Help: Hydraulic clutch bleeding
By RED98Z28CAMARO in forum Manual TransmissionReplies: 5Last Post: 09-06-2009, 09:13 AM -
Need new clutch or is this a hydraulic's problem?
By chris5 in forum Manual TransmissionReplies: 4Last Post: 05-27-2009, 08:12 AM -
Tranny, Clutch, or Clutch Hydraulic System?
By IZNUTHN in forum Manual TransmissionReplies: 2Last Post: 07-31-2007, 06:13 PM -
possible clutch hydraulic problem?
By chris5 in forum Manual TransmissionReplies: 4Last Post: 06-26-2007, 03:41 PM -
clutch hydraulic problems
By ls1transam346 in forum Manual TransmissionReplies: 1Last Post: 03-19-2006, 06:59 PM
