Results 1 to 1 of 1
Thread: Gen V LT1 Yukon Carnage
09-08-2024, 05:30 PM #1
So I fell victim to the dreaded Gen V AFM/DOD lifter failure or the 2014-18 valve spring failure that GM seems to love to give but not fix.
Lifter bore
Found this in the oil pan
Why did they design the oil drain higher then the bottom of the pan?
#5 cylinder intake lifter
Only rod bearing that had debris hit it
All the mains had debris go thru also
And the lucky #5 cylinder intake valve spring
Block, crank, rods and heads are dropped off at machine shop. The lifter bore is getting sleeved, all are getting looked at to make sure no other damage.
Shop informed me that all gm v8's from 2014-2018 are having valve spring issues, bad batch or something. He pointed out 4-5 more springs he felt they were about to let go just by how they looked. They were not seated right, looked like they were leaning to one side.
So the plan is AFM/DOD delete with new cam and valve springs, refresh the internals like timing chain, oil pump etc, new bearings all around, refresh the heads. Will update as it goes.Last edited by SMWS6TA; 09-08-2024 at 05:39 PM.
6.0L Block - Forged 403ci, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
A BAN must be passed now to end this carnage!!
By RATCHETMASTER in forum Political / Debate ForumReplies: 96Last Post: 01-25-2013, 03:46 PM -
Flexplate carnage
By c5z28 in forum Automatic TransmissionReplies: 10Last Post: 08-13-2011, 12:04 PM -
10-bolt CARNAGE...ENJOY!!!
By Roastem in forum DrivetrainReplies: 5Last Post: 03-29-2007, 11:42 AM -
LT1 in a 3 gen
By itsyasoldier in forum Camaro / SSReplies: 4Last Post: 04-16-2006, 07:26 AM
