Results 1 to 3 of 3
Thread: Transmission
07-19-2024, 06:02 PM #1
- Jul 2024
- Missouri
Red- 2004 Silverado SS
Transmission
Hello , I'm new to the site. I have a 2004 Silverado SS which I had the rear main seal replaced and the gentleman at the shop cut the cooler lines because he couldn't get the clips off. He the spliced in rubber hose ( didn't find out till the wife went to work the next day and it burst. Metal in fluid . It is a 4L85-E . I'm looking for recommendations on what to do should I have it rebuilt or go another direction?
Thanks in advance
08-01-2024, 08:26 AM #2
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
The number one thing that comes to mind is have you talked to the shop that did the ream main seal and cut the cooler lines? It was their cutting of the cooler lines that created this problem, they should be liable for the damage.
As far as the repair, is it a lot of metal, or little? Chunks or fine material? Once/if you fixed the lines does it drive normally?SLP Air Lid/Smooth Bellows
Elite Engineering PCV Oil Catch Can
SLP Smooth Air Lid and Smooth Belows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @ 415 rwhp
Weight reduction via removal of dead mice
08-01-2024, 08:34 AM #3
- Jul 2024
- Missouri
Thank you for responding. I did talk to the shop and I took it to another shop to be rebuilt. The gentleman at the shop that rebuilt it said the bolts on the transmission were finger tight and some were missing. I just picked it up this morning and we seem to be good again.
About the transmission
By Shoyoas in forum LT1Replies: 10Last Post: 03-05-2009, 03:03 AM -
New gm transmission
By absolutetraction in forum Automatic TransmissionReplies: 3Last Post: 07-17-2008, 03:36 PM -
Transmission
By axcellclan in forum Parts Wanted / TradeReplies: 0Last Post: 04-18-2007, 03:48 PM -
Transmission
By 2001bird in forum DrivetrainReplies: 1Last Post: 11-29-2006, 08:08 PM
