Thread: Seats
    Aug 2008
    canada
    1999 camaro ss
    Seats
    Looking for seat cover and foam options for my black 1999 ss with beige interior. Anyone have any experience/recommendations?
    Seats
    I've look for 3 yrs for replacement foam and no one makes it. I ended up getting aftermarket seats because the cost to have a shop make them and recover came up to the sames as the seats. easy decision for me. plus the Braum A1 seats are just so comfortable and chef's kiss in looks compared to stock steats.
    Aug 2008
    canada
    1999 camaro ss
    I was hoping to retain factory look. Do those seats work with your wiring so that power seats are still functional? Do you have a picture of how it looks in your car?
    I Appreciate your response, thanks!
    Not in the slightest bit. They are a non-power seat. You will need to fab something up to get them to mount to the stock rails or get a mount that will work but I still had to modify and fab up something to get it to sit right for me. I'm 5'8 and the only mount that I found that would work put the seat way to close for me. I can't imagine a taller person ever being able to use that rail mounts that were suggested to be used. The issue is the rails they recommend only slide about 4-5 inches.
    To retain the factory look you probably will need to talk to an upholstery shop. I'll have to get a pic and post.
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by racingrev View Post
    If the problem with the foam is that its been compressed/worn down, most interior shops can add foam to “rebuild” the seat cushion to its (more or less) original level of size and cushioniness. These days, I think it would probably be under $200.00 to do the two front seats (it cost me about $75.00 to get both done about 8 years ago).
    A few years ago, I picked up a passenger front seat, from a low milage car, to use as extra parts for when I rework my front seats, as that seat was a lower milage passenger seat, there shouldnt have been anywhere near as much wear and tear put on it as my 221k mile car seats had.
    SLP Air Lid/Smooth Bellows
    L76 6.0L block, PRC Ported 243 heads, Texas Speed 228R cam.
    Elite Engineering PCV Oil Catch Can
    SLP Smooth Air Lid and Smooth Belows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Strano Master Cylinder/Firewall brace
    dynoed @ 472 rwhp
    Weight reduction via removal of dead mice
  1. For Trade: My Camaro seats for TA seats
    By transamgirl89 in forum Parts For Sale / Trade
    Last Post: 05-03-2010, 05:49 PM
  2. Trade 01 ss seats W/DVD in both seats
    By ssweet99ss in forum Parts For Sale / Trade
    Last Post: 01-19-2009, 07:46 PM
  3. trade: ebony 02 WS6 seats, for grey CAMARO seats
    By DADillac in forum Parts Wanted / Trade
    Last Post: 10-11-2008, 04:37 PM
  4. WTB Black Leather SS seats or Black Racing Seats
    By claytonr in forum Parts Wanted / Trade
    Last Post: 09-10-2007, 09:58 AM
  5. Replies: 18
    Last Post: 11-06-2005, 01:58 PM
Tags for this Thread
