Results 1 to 2 of 2
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    Clutch/shifter problems?
    2002 SS Camaro..77,000 miles.. It had been sitting and not started for months..(I know I usually never let that happen in the past).
    Like an ass..I started it up went a few blocks .I got on it...shifted pretty fast then when trying to go into 3rd it wouldn't..Coasted in neutral pulled over to the side and couldn't get it into ANY gears!
    I pumped the clutch pedal and it went up and down fine..but still wouldn't go into gear it ..Got a tow..next day Car off goes into gears ..when I start the car wont go into gear. car running clutch pedal down 1st gear nothing..If gears in first, clutch pedal down and I release clutch let go nothing,,shut car off put into gear clutch pedal down start car it lurches forward?...someone suggested I need to bleed the clutch? MC. any help would be good! Maybe because it was sitting there was air? in lines or no pressure in it?...
    Thanks.
    Dec 2017
    Hinesville, GA
    There might be air in the system. My friend mechanic worked on a neat Camaro SS with a shifting issue and soft brake pedal. The owner ordered a set of toyos from 4Wheelonline and friend bleed both the brake fluid and clutch.
  1. Help: Shifter problems
    By HadleyGto in forum GTO
    Last Post: 02-06-2011, 07:40 PM
  2. Clutch problems......
    By steve00ss in forum Manual Transmission
    Last Post: 08-16-2010, 06:10 PM
  3. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
  4. Clutch Problems NEED HELP!!!
    By miller456 in forum Manual Transmission
    Last Post: 07-13-2007, 01:06 PM
  5. clutch problems please help
    By adam0321 in forum General Help
    Last Post: 04-12-2007, 12:39 PM
